Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 53
  1. #16
    Default corrupted file
    file not currupted was able to download, extract and install no problem
  2. #17
    Top Poster torqueman's Avatar
    Canada
    Quote Originally Posted by diesel-tech View Post
    this one is newer than 2.6
    Bro,
    Can you please load it again.The link is dead.
  3. #18
    Default mack 2.94
    http://rapidshare.com/files/44013653...ss_v_2_9_4.exe
    ok here it is for the people that requested it
  4. #19
    Default DEALER PROGRAMMING
    FOR ANY BODY THAT NEEDS IT AND HAS USE FOR IT, THIS IS FOR VMACK III DEALER RPOGRAMMING ONLY LATEST FILES http://rapidshare.com/files/44020727...stallation.zip
  5. #20
    Canada
  6. #21
    Member catfan1's Avatar
    Sep 2010
    well me ask a dumb question is vmac to proper software to communicate with mack truck. If it is is it hard to install and run compared to cat or insite?
  7. #22
    DK Veteran hercamp's Avatar
    only supported xp sp2 and works in vertions vmack II and III...enjoy
    the life is easy... people complicate!!!!!!!!
    life is funny just step away of people that wants make your life a shixx
    http://youtu.be/PEw3nYmpEys
  8. #23
    Sep 2010
    Does anyone have client to install vcads?
  9. #24
    maybe in other thread!!!!!!!! man......
  10. #25
    Sep 2010
    Quote Originally Posted by catfan1 View Post
    Im sorry I meant client ID. I can start loading the VADS program but dont have a Client Id to finish running it but I will still look.
  11. #26
    Default help me
    amigos buenas noche tengo un problema con el software de mack lll , si alguien me puede ayudar se los agraderia mucho . instale el programa y los driver de nexiq pero en preferencias no me reconose los driver de nexiq y no puedo conectarme .
  12. #27
    did u use the usb link fix on post #20? to
  13. #28
    "amigos buenas noche tengo un problema con el software de mack lll , si alguien me puede ayudar se los agraderia mucho . instale el programa y los driver de nexiq pero en preferencias no me reconose los driver de nexiq y no puedo conectarme . "
    macromantis, I think the problem is your keyboard. The text is all scrambled. Replace it and let us know if that fixes your problem. Also check the rules section. There may be a few tips there on getting your adapter to work.
  14. #29
    Top Poster Juanincho's Avatar
    Aug 2010
    Macromantis, en este foro debes usar ingl?s
    Translation: Macromantis, in this forum you must use english.
  15. #30
    Apr 2011
    amigos primero que nada muchas gracias por los link realmente e tenido muchos problemas con los camiones mack como por ejemplo,granite,vicion,pinacles.
    alojor estoy haciendo algo mal con el softwares VMACK III lo necesito con urgencia serian tan amables en poder ayudarme con este problema que tengo nota instale tambien el ssoftwares VCADS pero entro en algunos modelos por ejemplo los vicion pero solamente pude mirar ni siquiera programar les envio una foto del error que me hace el softwares pleace heeeeeeeeeeeeelp
