the only way to solve the problem is contact cmd service because your cmd flasher is now deaktivated
HI
I have problem with original CMD FLASHER.
In my pc, i had soft for BDM clone before install original.
Original CMD work good, but i use clone one time and since Original CMD don't work.
I reinstall the software original but don't work ( interface no found ).
How I can cleaner my pc for reinstall corectly original.
I already contact CMDTEC and it said my interface is no blocked.
I install this in other pc and it work.
when you install the clone version, it patches some files..you must find a way to un-patch them or delete them.
Search the entire pc, registry etc.
You know you can change a hard drive in your lap top, they are pretty cheap nowadays. That way you can have all your legit software on one and all the cracked one on the other.
I got about 8 .
Best Regards, Roth.
ok
2 hard disk is good solution for future.
But now how I can cleaner my disk???
please i need reinstall cmd original in my first pc.
Format pc, and reinstaling cmdflash original.
Regards.
I have lost of soft in my pc and i would like to keep this.
after the clone installation there a 2 files in windows/system32/,
delete them and install the org soft from cmd
the files are certificate information *.crt i think
I already try to delated this two but no success.
I think I try format.
you m8 use one of does cleaner !
this one is free and very good !
Marcos Velasco
[QUOTE=m8[/QUOTE]
Sorry i no undestant that (m8).
Could you explain yhis word.
I clear all system file and drivers cmd/bdm,clear reestr,and reinstall,works
