Results 1 to 15 of 19
Hybrid View
    Default ECU blocked since UPDATE
    I need unblocked ecu fo 307SW ecu SID 803.
    I t is blocked since PEUGEOT UPDATE.
    Could find a file for restart this car?
    EU
    Quote Originally Posted by CIRCUIT.FR View Post
    If it is helply for You i can send You bdm files of worked Peugeot 407 SW with sid803 ecu.
    unar
    Ok
    send me this. If first no work and try this.
    Quote Originally Posted by unar View Post
    unar
    EU
    Ok
    Here You have from P307 Sid803. I made this 307 today with BDM.
    If it is helpful for someone , please for little thanks
    unar
    But could you extract each file, my bdm have problem....
    unar
    EU
    Hi, inside You have BDM full file and earlier flash, mcu and eeprom files.
    Regards and post results
    unar
    Hy,try this file:
    I try and no good
    Bad checksum
    Quote Originally Posted by rasequia View Post
    Hy,try this file:
    Just flash the original Peugeot file, ECu do not block after update..there is womething that you have done..
    DK Veteran rsibiza's Avatar
    Wink
    It may possible to have write protection.
    Some ecu's as example EDC15 from ABT,have some soldered pcb inside with flash 29Fxx you can read Flash,but will ahve error...but not able to write correct...will be damaged...
    DK Veteran rappttor's Avatar
    PERPETUUM MOBILE
    there is another disscusion about this type of ecu on dk...what tools did you use until now on it?
    Moon
    I had some problems with this type of ECU. How did you updated the software? PPS, BDM or other?
  13. #13
    With PPS
    I try new file, now i can diag again but car no start.
    I have this fault (paper test)
    I have problem with immo code.
    Soluce?
