Page 7 of 8 FirstFirst ... 2345678 LastLast
Results 91 to 105 of 108
  1. #91
    EU
    Default work dump from first post!
    Quote Originally Posted by doktorabg View Post
    Not work!!!
    To all members - read and write like 59C11 with any normal eeprom programmer - UPA is not smart programer, don't use it for this job
    Member Min2xx has right - cut wires
    Work my dump.
    Car start
    The dump from first post is ok, I read and write with upa as 93C56 and car start, also I do 2 tipes of ecu (...881D and ...881C)with this dump and both goes well .Something strange, I read with upa and not work(even I can read and write as 93c56 X16), I inslall upa on another laptop, and work ok!
    Tll 866 not working
    Regards!
  2. #92
    Aug 2016
    today i programm the OKI M951G with x prog m. with device: 93xx56b , b is for 16 bit. and than go under option envioremt and deactive the option on reading and writing without verify so you can write. it came error while programming but click on YES to ALL and than repaet it if its 100% (about 10x ) . now you can desolder it and cut 54 and 62 cable witch came from 7b and 6b
  3. #93
    Sep 2016
    Hello ,
    Is there any solution for this problem that does not need to remove engine check light , or cutting any wires to the central locking work fine ?
    Just asking cause this thread was opened a while ago , and i have got this problem at the moment .
    If I could send my dump to anyone , would be very appreciated , cause i dont have any immo removal software .
  4. #94
    felix_fetche's Avatar
    Baia Mare
    Dump from first post i just used and works charming. I use ELNEC MemProg, selecting MSM16951.
    On KIA Sportage 407913-1741.
  5. #95
    Jun 2016
    Default Dump works perfectly
    This dump from the first post works perfectly. I read it with UPA USB. Before connecting ECU on car, I've disconnected IMMO box, because I don't have remote controls. Car starts without any problems, but CHECK lamp is lighting up, so I had to pull it out.
  6. #96
    Nov 2011
    Programed with X-Prog 93c56 16bit. Works great!
  7. #97
    Mar 2014
    Spain
    Read with 93C46 x16 and program with 93C56x16, then works
  8. #98
    AndyCZ's Avatar
    Jan 2014
    EU
    I read/write with O5 as MSM16951. Used dump from first post.
    Cut 54 and 64 pins on ECU.
    Car start like a charm
    Many thanks.
    If I helped you know what to do..
  9. The Following 2 Users Say Thank You to AndyCZ For This Useful Post:
    jurlak1 (16th December, 2022), madbg (4th April, 2024)
  10. #99
    Jan 2017
    Quote Originally Posted by jvm2010 View Post
    Hi guys!
    This is a tested and working immo off solution for the infamous ZEXEL K04R that comes with KIA SPORTAGE 2.0TD.
    You have to take out the OKI M951G EEPROM in the ECU and write the dump attached in this post.
    You must read and program the OKI EEPROM as a 93C56 (forget 93C46).
    Notes:
    *The check engine light will be on after applying that immo off file, but the car will work flawlessly, you can take it out or leave it on, as you wish.
    *To be able to use the remote control to open/close the doors you must cut cables number 6 an 7b on immo box.
    That's all.
    Kind regards!
    Just to inform that i tried this dump today and it worked great.
    I read and write with original carprog the OKI eeprom as 93C56 and no problem…
  11. #100
    Feb 2017
    How do I download?
    Why can not I download it?
    I have no right from admin?!
  12. #101
    Feb 2017
    I need this file.
  13. #102
    Feb 2017
    How can I receive it?
    Please!
    my mail is - alpina_m_tehnik@abv.bg
  14. #103
    Mar 2017
    I cannot download file from first post. Can someone send to my mail kapcok025@gmail.com
  15. #104
    Oct 2017
    PT
    is it still possible to download the file? or can someone reload it?
    thank you!
  16. #105
    Dec 2012
    GARAGE
    Hello DK members!
    I have problem with immo off on this car.
    Car: Kia sportage 2.0td 2000r
    Ecu : Zexel 0K04R 18 881 E
    407913-1743
    eeprom: OKI M951G - read as 93c56 16bit
    Immobox removed, 2 pin cut in ecu.
    I tried immo off file from firs post but there is only an impulse on the fuel cuting valve on the pump, the connected bulb will flash only once and go out.
    So decide to try with carlabimmo julie pro emulato,but no power at all- even one flash.
    I checked the power supply on ecu and everything looks ok.
    I know that this dump work with ecu B,C,D at the end but my is E.
    Maybe you have some experince, or solusion with this ecu number.
    if anyone could help I would be grateful.
    BR
