joze (6th June, 2017)
it is ok. I've sent already today at: http://www.digital-kaos.co.uk/forums...-crash-175931/
obviously i need help here, getting the same message from VAG eeprom programer with 409.1 VAG-COM cable = "No ECU Found" Anyone knows how could i solve it? I mean i need to clear crash data. I have opened the controler and it has the motorolla chip inside. its SC513013CFU.
Need help....
k-line is next pin in left side (+ and -is ok)
capi (9th August, 2018)
K-Line on 54 pin. You can try to clear crash by air.exe program from pure DOS by Com-K-Line adapter.
Try this
Pinout AIRbag.pdf
VW.rar
thanks for info zaveruha
no luck for me, with air still getting "Time out 60" do probably the only way there is left is a programming the chip vis programer?
or maybe i could short some pins and then it will start to respond?
by the way via canbus i can connect to it, read faults.
[QUOTE=colouny;870994
[/QUOTE]
No.
Did you try to connect by Vag-Com from K-Line not CAN? If you cant connect its mean unit does not have K-Line, and you mast use Vag K+CAN Commander or programmer.
Try connect on car.
Hello.
Who will send me the pinout for the VW51 1c0909605k the PM, because I can not download files mentioned in the forum.
Thank you.
