First What tool do you use to read your car?
I greet all. I first of all wanted to greet with you and from mountain to apologize for my English.
I want to to play away and to modify in aster one's ECU and all this under control of system windows 7 64 bit.
Unfortunately near test of lecture the ECU near 66% jumps out me the error with announcement that I have something to make by 1sek. About what does it in this walk??
I would ask about help near modification of maps also, if I ask this possible this step after step to support me in measure your possibilities.
I greet, ***321;ukasz.
Post the file that you extracted from the ECU. if you managed to exctract any
this will write so, Astra then model with 1999 year from engine 1,7 dti and driver DELCO. I am sure it that was can read from ECU map because some 3 months was install chip ago. Guy to this aim arranged original programme from ECU and he altered him. Astra has 93km at present and 201NM.
I wanted to to play away programme and to modify him more yet.
if ecu is bosch then car is 68hp and engine is x17dtl not y17dt. post here exact HW and SW number you read by identifing you ecu via OBD
Identify your ecu with dignosis tool, or take a photo of the sticker on the ECU. i ll give you the original file of that ECU, taht you can mod your way and just write it.
my motor this y17dt. I know with what I go, this should be by factory 75km and 165Nm.
I will make tomorrow and I will put picture ECU
how can i find out if i have y17dt or x17dtl?
the car s techical doc
to be visible all here - engine this 1,7 DTI 16V 75KM ISUZU
To make a mistake ISUZU 75KM hard and engine oplowski 68KM
Well ECU is DELCO lpv4 SW DCWB.
Here is the original ... I have done several of these. From what I know this ECU doesn't support cruise control function.
It supports cruise control, if somebody don't have can do mode, its quite easy 4 cables, and opcom
