Results 1 to 7 of 7
    Apr 2009
    Default dm500 help with tring card
    i have 2 dreambox dm500 and a tring card which has conax encryption and i want to watch it on 1 of dms but when i put the card on it says no or unknown card inserted
    i wanted to keep 1 dm500 in the living room and the other in my bedroom or at least i need to get it to work on one of the dms
    now i've read that it can be done through cccam/newcs and the problem is that i cant get it to work i dont know how
    i use gemini 4.7 and cccam 2.2.1
    so if some1 knows how to do that and helps me
    that would make me happy plzzzzzzzzzzz Help
    Thank you in advance
    plzzzz some1
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    got this from another site ,, l have no idea myself
    ok i will give the hole cfg so that you can replace yours
    <?xml version="1.0"?>
    <newCSconfig>
    <readers name="Card Readers">
    <device>
    <name>SCI Lower Slot</name>
    <type>sci</type>
    <mhz>357</mhz>
    <node>/dev/sci0</node>
    <parity>odd</parity>
    <reset>normal</reset>
    <export>Yes</export>
    <enabled>Yes</enabled>
    <blocksa>No</blocksa>
    <blockua>No</blockua>
    <blockga>No</blockga>
    <blockC0>Yes</blockC0>
    <carddetect>no</carddetect>
    <newcamd_port>15000</newcamd_port>
    <autosid>Yes</autosid>
    <pincode>0000</pincode>
    <priority>round</priority>
    </device>
    </readers>
    <radegastserver>
    <enabled>no</enabled>
    <port>10003</port>
    <allow>ALL</allow>
    </radegastserver>
    <cache>
    <emm>10</emm>
    <ecm>10</ecm>
    </cache>
    <debug>
    <level>normal</level>
    <type>init</type>
    <output>console,udp,tcp</output>
    <logfile></logfile>
    <console_options></console_options>
    <file_options></file_options>
    <udp_host>192.168.1.232</udp_host>
    <udp_port>1000</udp_port>
    <udp_options></udp_options>
    <tcp_port>3001</tcp_port>
    <tcp_options></tcp_options>
    </debug>
    <httpd>
    <server>
    <port>8080</port>
    <enabled>yes</enabled>
    </server>
    <user>
    <name>admin</name>
    <password>admin</password>
    <accesslevel>admin</accesslevel>
    </user>
    </httpd>
    <newcamdserver>
    <deskey>01 02 03 04 05 06 07 08 09 10 11 12 13 14</deskey>
    <name>newcs</name>
    <userfile>/tmp/users.txt</userfile>
    <user>
    <name>user1</name>
    <password>pass1</password>
    <au>on</au>
    <allow>lower</allow>
    <allow>upper</allow>
    </user>
    </newcamdserver>
    </newCSconfig>
    try it like this and add a n line on your cccam.cfg like this
    N: 127.0.0.1 15000 user1 pass1 01 02 03 04 05 06 07 08 09 10 11 12 13 14
    restart cccam-newcs and it will work
    Apr 2009
    <newCSconfig>
    <device>
    <type>sci</type>
    <mhz>357</mhz>
    </device>
    </readers>
    <radegastserver>
    <port>10003</port>
    <allow>ALL</allow>
    </radegastserver>
    <cache>
    <emm>10</emm>
    <ecm>10</ecm>
    </cache>
    <debug>
    <type>init</type>
    <logfile></logfile>
    </debug>
    <httpd>
    <server>
    <port>8080</port>
    </server>
    <user>
    <name>admin</name>
    </user>
    </httpd>
    <newcamdserver>
    <name>newcs</name>
    <user>
    <name>user1</name>
    <au>on</au>
    </user>
    </newcamdserver>
    </newCSconfig>
    this is for newcs.xml right
    Apr 2009
    oh and what is this
    this ip is for?
    Apr 2009
    smirnoff_rules thank you very very much for your help
    Mar 2008
    birmingham
    no prob .. is it all working now ,, did u have to change anything or just paste in ?
    Apr 2009
    i think that this is a line to connect to newcamd server m8
    am i right?
