Results 1 to 8 of 8
    Top Poster ricz's Avatar
    Nov 2010
    UsA
    Default What kind of cleaner do you use to flush a coolant system?
    Hi. Im wondering what do some of you guys use to flush a coolant system after a replacement of a bad oil cooler (like a cat or even better an isx). At my work what we have been doing is draining the coolant with all the sludge from the oil, dipping a rag or flushing the reservoir (if it can be removed), then filling it up with water and automatic dishwasher soap, letting it run for about an hour then draining the water/soap. Then just filling it up with water.
    DK Veteran mondao's Avatar
    we use a bit of diesel mixed with detergent, also remove the thermostat so that the solution to flow throughout the engine
    about three times so that it is clean, very important to change the coolant filter
    Nov 2010
    UsA
    yeah I forgot to mention the filter, but I hardly see any cat (3406 or c15) with water filters/corrosion inhibitors. Yeah we never have taken the thermostats out, I'm gonna start doing that.
    Sep 2008
    might have been a few posts around the forum,think someone mentioned cheap cola,never tried it ,i would be worried about detergents and diesel,rotting hoses.
    sometimes when the amount is too much with oil in the coolant system, I have to use about 15 liters of diesel and washing powders (detergents)
    this in the first wash, because you have to do like 4 or 5 times to make it clean the coolant system, and only a few minutes ago, because without the thermostat, clean soapy water all the hiding places of the engine and radiator
    after washing the system, installing the thermostat again, and spoke of the ISX
    sry my inglish
    drakov's Avatar
    Aug 2008
    Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
    I use dishwasher detrergent , it wont foam and does the job. but cummins makes a cleaner called restore it works good to, but dishwasher works good.
    Top Poster mecanico112's Avatar
    Hello.
    We have had problems with the coolers and we have also used Deutz Fortes.
    The issue price.
