Results 1 to 7 of 7
    Dec 2010
    Default Programing Chrysler 300C Challenge Code?
    So i tried programing a 2005 Chrysler 300C Today and i failed.
    i was using the Chinese Version of the MVP i had the right pin code but at the end it gave me A Challenge code and asked me for a alphanumeric code.
    i found some info right here http://spidometrs.ru/s2/download/Chrysler_Manual.pdf
    and it says that the code will be obtained Form Advanced diagnostic.
    is there a way around that?
    i'm Getting my new SBB tomorrow will that be able to program a key W/O A challenge code?
    Thanks!
    Last edited by shaykie; 6th December, 2010 at 11:53 AM. Reason: being more specific.
    DK Veteran Automat's Avatar
    Chuichu village, AZ
    Quote Originally Posted by shaykie View Post
    Thanks!
    Others have posted unsuccessful results with Chrysler using the SBB, but I believe SBB does not ask for challenge codes.
    Dec 2010
    Quote Originally Posted by Automat View Post
    If the SBB is a fail with Chrysler cars what Would be the best programing tool for chrysler?
    i own a MVP, SBB Both are pretty unreliable but you get what you paid for... and i'm willing to buy anything (as long as i can find a Chinese version of it) that will allow me to program Chrysler cars.
    Thanks!
    I have a t300 that does chysler but it did not work till I got the right adapters. never had a car with challenge codes though. but worked great on cars I have done so far mostly type 2 and pacifica systems
    Dec 2010
    Quote Originally Posted by brightlockandkey View Post
    Thanks,
    Any idea what cables are they?
    is it the original advanced Diagnostics cables? ADC138 And ADC139?
    Those cables are at about $190 per cable, expensive but if it works it's totally worth it.
    Thanks again, and if you can forward me to where i can get the cables from id greatly appreciate that.
    well I just have the adapters not whole cables. I will send you a message with where I got them.
    gojko's Avatar
    Vrsac
    I have the original SBB and is required to pin that I'd programmed
