Results 1 to 15 of 18
    Rito's Avatar
    Default For Enigma users
    Today I try change Renault ScenicIII.....But enigma can?t do it.
    Enigma can?t read 24C16, always show frist 3 pins red...
    I try read in epron 24C16 in editor but same this 3 pins red...and not for bad conection I test whit other epron and it?s ok..
    Dealer says epron have fund in dash is 24Lc16 but I have sure I fund 24C16.
    Someone have same problem???
    uk
    remove eeprom press read {3 pins red } continue anyway see if it gives correct miles if yes save file and carry on programming......
    can't remember exactly which eeproms but some eeproms show bad connection enigma does not need them connection to read and write.......
    DK Veteran Digamax's Avatar
    Serbia
    Quote Originally Posted by raf0468 View Post
    Yes that is normal for eeprom 24c16 (3 pin red). Continue anyway.
    Best regards
    Vladimir
    Rito's Avatar
    If I try continue to read this not read correct value....
    So you can do some car like this??
    Maybe have other versions dash or machine not work whit this car....
    einet's Avatar
    24LC16 in some cases is Roteted.
    I have the same problem on a Clarion Radio that have this eeprom roteted.
    Land of Rocks
    Quote Originally Posted by einet View Post
    If you say so please post datasheet with this chip rotated pins.
    T72's Avatar
    Sep 2010
    Quote Originally Posted by tachonow View Post
    megane3/scenic3/laguna3 do not have any rotated 12c eeproms..
    its simple clip problems...
    dashradio's Avatar
    Inafield
    I have never seen a Clarion radio with a 24c16 in it ? only 93c46 rotated pins.?
    United Kingdom
    Enigma certainly can do this vehicle as I have done them myself. They work fine with the chip onboard. If you do take the chip off I think you will find that pins 1, 2 and 3 are all linked on the pcb.
    Serbia
    Quote Originally Posted by Rito View Post
    Which voltage you use for reading? 4.5V is very good voltage for reading. I always desoldering eeprom from board.
    Best regards
    Vladimir
    einet's Avatar
    Sorry! I answer to quickly .
    Correct that whose 93C46 rotated. and this whose a
    old Clarion Radio for Peugeot.
    Back of a van
    24c16 using enigma always 3 pins shown as no connection ( "red" ) just read past it and you should be ok as I never have an issue this way. The same goes for programming 24c16
  13. #13
    Rito's Avatar
    Quote Originally Posted by Digamax View Post
    Best regards
    Vladimir
    I use 3.5..
    I try read chip outsid pcb but not correct value and show 3 pins red..
    Maybe Enigma not know this version??
  14. #14
    dashradio's Avatar
    Inafield
    Hi, try this if reading 24c16 out of circuit, join pins 1,2,3 & 4 together.
  15. #15
    United Kingdom
    Rito the enigma will definately read this onboard. Read the eeprom and take a look at the data. You should also be aware that you will also have to fit a filter in the dash as it will write back the mileage from the ABS module. So if you dont have a filter ready to do the job you are wasting your time trying.
