Results 1 to 15 of 18
Hybrid View
    Jan 2010
    uk
    remove eeprom press read {3 pins red } continue anyway see if it gives correct miles if yes save file and carry on programming......
    can't remember exactly which eeproms but some eeproms show bad connection enigma does not need them connection to read and write.......
    DK Veteran Digamax's Avatar
    Jan 2010
    Serbia
    Quote Originally Posted by raf0468 View Post
    Yes that is normal for eeprom 24c16 (3 pin red). Continue anyway.
    Best regards
    Vladimir
    Rito's Avatar
    Jan 2010
    If I try continue to read this not read correct value....
    So you can do some car like this??
    Maybe have other versions dash or machine not work whit this car....
    Jan 2010
    Serbia
    Quote Originally Posted by Rito View Post
    Which voltage you use for reading? 4.5V is very good voltage for reading. I always desoldering eeprom from board.
    Best regards
    Vladimir
    Rito's Avatar
    Jan 2010
    Quote Originally Posted by Digamax View Post
    Best regards
    Vladimir
    I use 3.5..
    I try read chip outsid pcb but not correct value and show 3 pins red..
    Maybe Enigma not know this version??
    dashradio's Avatar
    Nov 2009
    Inafield
    Hi, try this if reading 24c16 out of circuit, join pins 1,2,3 & 4 together.
    Apr 2010
    United Kingdom
    Rito the enigma will definately read this onboard. Read the eeprom and take a look at the data. You should also be aware that you will also have to fit a filter in the dash as it will write back the mileage from the ABS module. So if you dont have a filter ready to do the job you are wasting your time trying.
