Results 1 to 10 of 10
    ION CRISTI's Avatar
    ROMANIA
    Default dashboard opel antara
    hello. i need picture testpoint dash opel antara 2008 . thanks
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by ION CRISTI View Post
    remove needles 93C86
    ION CRISTI's Avatar
    ROMANIA
    solved thanks. but i need edit km. in present 208373km and i need 126200km
    drpeter's Avatar
    The Netherlands
    I don't have script here, only at home, I am home tonight, if you can't wait so long ask another member.
    mastaflex's Avatar
    Jan 2009
    FR47310
    use this algo:
    Car type: Opel Antara - 93c86 - 2007-2009 years
    The mileage is stored in the next lines:
    0000: A8 00 00 61 A8 00 00 61 A8 00 00 61 00 00 00 00
    0010: 00 00 00 00 xx xx xx xx A8 00 00 61 A8 00 00 61
    0020: A8 00 00 61 00 00 00 00 00 00 00 00 xx xx xx xx
    0030: A8 00 00 61 A8 00 00 61 A8 00 00 61 00 00 00 00
    0040: 00 00 00 00 xx xx xx xx A8 00 00 61 A8 00 00 61
    0050: A8 00 00 61 00 00 00 00 00 00 00 00 xx xx xx xx
    0060: A8 00 00 61 A8 00 00 61 A8 00 00 61 00 00 00 00
    0070: 00 00 00 00 xx xx xx xx A8 00 00 61 A8 00 00 61
    0080: A8 00 00 61 00 00 00 00 00 00 00 00 xx xx xx xx
    0090: A8 00 00 61 A8 00 00 61 A8 00 00 61 00 00 00 00
    00A0: 00 00 00 00 xx xx xx xx A8 00 00 61 A8 00 00 61
    00B0: A8 00 00 61 00 00 00 00 00 00 00 00 xx xx xx xx
    00C0: A8 00 00 61 A8 00 00 61 A8 00 00 61 00 00 00 00
    00D0: 00 00 00 00 xx xx xx xx A8 00 00 61 A8 00 00 61
    00E0: A8 00 00 61 00 00 00 00 00 00 00 00 xx xx xx xx
    00F0: A8 00 00 61 A8 00 00 61 A8 00 00 61 00 00 00 00
    0100: 00 00 00 00 xx xx xx xx A8 00 00 61 A8 00 00 61
    0110: A8 00 00 61 00 00 00 00 00 00 00 00 xx xx xx xx
    0120: A8 00 00 61 A8 00 00 61 A8 00 00 61 00 00 00 00
    0130: 00 00 00 00 xx xx xx xx A8 00 00 61 A8 00 00 61
    0140: A8 00 00 61 00 00 00 00 00 00 00 00 xx xx xx xx
    0150: A8 00 00 61 A8 00 00 61 A8 00 00 61 00 00 00 00
    0160: 00 00 00 00 xx xx xx xx A8 00 00 61 A8 00 00 61
    0170: A8 00 00 61 00 00 00 00 00 00 00 00 xx xx xx xx
    where the next bytes:
    A8 00 00 61 A8 00 00 61 A8 00 00 61 00 00 00 00 00 00 00 00
    - - is a mileage
    but put 3E00007B3E00007B3E00007B0000000000000000 as 126200KM
    ION CRISTI's Avatar
    ROMANIA
    ok solved. but edc16 not work change. i use edc16km opel v1, read original but noy write
    mastaflex's Avatar
    Jan 2009
    FR47310
    think is better to do manually. open ecu and read eprom.
    it's a 95160
    drpeter's Avatar
    The Netherlands
    Never done this but sometimes you must remove dash fuse to program EDC. You can try.
    mastaflex's Avatar
    Jan 2009
    FR47310
    have to do it for VAG cars when write ECU. it's a good idea to try before removing ecu.
    ION CRISTI's Avatar
    ROMANIA
    i try tomorow write ecu without fuse dash
