Thanks Ash
Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
hello everyone I have a problem with the machine inadvertently Autocom have given the firmware update has stopped working and you have a solution or I have to send the dealer is not original clone.
Hi!
I have problems with my 5th unit, all bought from the same seller.
This one is not working at all, no comunication with all cars.
When pluged in OBD ligts up 2 red leds, on other unit I have is one red and one green (this become red when USB is connected) on this the red LED become orange when plug USB... maybe the connected LED in wrong way?!
When try to connect to car, the third LED (green) lights and relay is turned on. Green LED and relay stays ON until I power off the unit by unplug OBD.
Any advice? Someone had the same problem?
Rite guys yesterday I received my new replacement autocom trucks unit tested it today and its working fine![]()
Thanks Ash
can someone recommend good dealer with very good 100% working autocom PLEASE>???![]()
I always use them and I am quite happy with them and this was the first time where I did get a faulty thing but. always send me good stuff............you can try them from me they are good suppler...
SZH Technology Co.,Ltd
Thanks Ash
Hi!
The board where bluetooth is OK, I have swapped the board with another working CDP. I noticed, that bluetooth modules are different, the "new" one has no connection to external antenna!
Also there is missing transistor near bluetooth like you sad, but this is same on both CDPs I have and works without.
I noticed also, that "new" one has 220uf/25V capacitors near connector (to OBD), the other one has 100uF/16V.
I think, that the problem is in main board...
EDIT:
I found different Microcontrollers on main doards: SAF-C167CR-LM (board works) and SAK-C167CS-LM (not working board)
HI
i have receive my autocom cdp 2011 to day but i can't install it
when i clic on start.exe from DVD there is an errors
i have desinstaled dotnetfx35_SP1.exe and instaled it again without probleme
but same probleme with instalation of software
is there an issue?
ok
after scan my computer with combofix this window is not
but now no think hapen when i clic on start.exe,only a dos window open and then close
i think i have a damaged dvd from china
some one can upload link for 2011-1 autocom CDP ?please
Got my Autocom today and have same sort of trouble.
Try start.exe and error no win32 program.
Tried on 2 different laptops running XP SP3.
Tryed general software_install.exe but then error wrong ID when filling the Id serial and Key.
Any suggestions?
now,i format my second computer and i will try to instal autocom software in fresh windows
i will let you know
i read some where that it must instaled on XP service pack1
and that it don't work with service pack2 and pack3
5mn and a new windows will be installed in my desktop
