Page 17 of 55 FirstFirst ... 7121314151617181920212227 ... LastLast
Results 241 to 255 of 823
Thread: autocom cdp
  1. #241
    Ashraf6119's Avatar
    Nov 2009
    UK
    Quote Originally Posted by 407ron View Post
    I have not tested autocom on a Focus 1.6 TDCI but if i do i will report back.
    I am just after opening up Autocom and i checked tru the ford focus menu and i see it FACM (additive system) is there so i guess it can be reset..:-)
    Ron.
    Yes I have the Original one and at that Version 2011-1 it already had that option............So hopefully the clone one should do the job............Remember the original one is at 2011-2 at the moment and soon will be 2011-3 ............Good Luck
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
  2. #242
    Sep 2009
    albujon el
    hello everyone I have a problem with the machine inadvertently Autocom have given the firmware update has stopped working and you have a solution or I have to send the dealer is not original clone.
  3. #243
    Dec 2009
    Hi!
    I have problems with my 5th unit, all bought from the same seller.
    This one is not working at all, no comunication with all cars.
    When pluged in OBD ligts up 2 red leds, on other unit I have is one red and one green (this become red when USB is connected) on this the red LED become orange when plug USB... maybe the connected LED in wrong way?!
    When try to connect to car, the third LED (green) lights and relay is turned on. Green LED and relay stays ON until I power off the unit by unplug OBD.
    Any advice? Someone had the same problem?
  4. #244
    meteor80's Avatar
    Dec 2009
    Poland
    Quote Originally Posted by alfy View Post
    Hi!
    Hello.
    Try to desolder bluetooth or check do You have two transistors near bluetooth.
    I had a similar problem and it was missing of one transistor.
    Work is a primitive way to spend Your free time.
    F.Kiepski.
  5. #245
    Ashraf6119's Avatar
    Nov 2009
    UK
    Rite guys yesterday I received my new replacement autocom trucks unit tested it today and its working fine
    Thanks Ash
  6. #246
    Mar 2010
    can someone recommend good dealer with very good 100% working autocom PLEASE>???
  7. #247
    Dec 2009
    Quote Originally Posted by omi1980 View Post
    I think is all about luck with china tools...
    I bought 5 autocoms from one seller and no one was equal, every tool was a litlle different in some or another way!
    4 work ok, now the 5th don't work at all...
  8. #248
    Ashraf6119's Avatar
    Nov 2009
    UK
    I always use them and I am quite happy with them and this was the first time where I did get a faulty thing but. always send me good stuff............you can try them from me they are good suppler...
    SZH Technology Co.,Ltd
    Thanks Ash
  9. #249
    Dec 2009
    Quote Originally Posted by meteor80 View Post
    Hello.
    Hi!
    The board where bluetooth is OK, I have swapped the board with another working CDP. I noticed, that bluetooth modules are different, the "new" one has no connection to external antenna!
    Also there is missing transistor near bluetooth like you sad, but this is same on both CDPs I have and works without.
    I noticed also, that "new" one has 220uf/25V capacitors near connector (to OBD), the other one has 100uF/16V.
    I think, that the problem is in main board...
    EDIT:
    I found different Microcontrollers on main doards: SAF-C167CR-LM (board works) and SAK-C167CS-LM (not working board)
  10. #250
    Jul 2010
    ALGERIA
    HI
    i have receive my autocom cdp 2011 to day but i can't install it
    when i clic on start.exe from DVD there is an errors
    i have desinstaled dotnetfx35_SP1.exe and instaled it again without probleme
    but same probleme with instalation of software
    is there an issue?
  11. #251
    Jul 2010
    ALGERIA
    ok
    after scan my computer with combofix this window is not
    but now no think hapen when i clic on start.exe,only a dos window open and then close
    i think i have a damaged dvd from china
    some one can upload link for 2011-1 autocom CDP ?please
  12. #252
    Aug 2009
    Netherlands
    Got my Autocom today and have same sort of trouble.
    Try start.exe and error no win32 program.
    Tried on 2 different laptops running XP SP3.
    Tryed general software_install.exe but then error wrong ID when filling the Id serial and Key.
    Any suggestions?
  13. #253
    Jul 2010
    ALGERIA
    now,i format my second computer and i will try to instal autocom software in fresh windows
    i will let you know
  14. #254
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Jul 2009
    Far far away
    DVD from China is crap m8.
    4C7570755F73616E64755F696D6D6F5F736F6C7574696F6E73
  15. #255
    Jul 2010
    ALGERIA
    i read some where that it must instaled on XP service pack1
    and that it don't work with service pack2 and pack3
    5mn and a new windows will be installed in my desktop
