Page 1 of 8 123456 ... LastLast
Results 1 to 15 of 106
    Default Astra H display pin???
    Hi All!
    Please help....
    I am need code in info display Astra H (eeprom 93C66).....
    jackeldestripador's Avatar
    S.A.
    Hi, with tech2 you can't change settings?
  3. The Following User Says Thank You to jackeldestripador For This Useful Post:
    ampibali (2nd February, 2022)
    I am need only pin code... Please help ....
    Here you go.
    Don't forget to say thanks once you have noted it down
    Thanks.......
    carradio2001's Avatar
    France
    Carradio2001.
    (Owner of CalcGen Made by I.S.A)
    THANKS ALL !
    And who tried it to replace code with another? If that be I will change where the code it is erased at once.
    Can on it is checksum?
    pecky, is your software availible anywhere, or is it only for your usage ?
  10. #9
    Quote Originally Posted by emes125 View Post
    I did it just for my use to save me manually looking up the info. I'm always happy to give codes if a dump is provided.
  11. #10
    Does TID display from Opel Meriva need security code and divorcing ?
  12. #11
    Yes it does, all the recent radios/displays are coded.
  13. #12
    Here is dump from 93C56 - Meriva A. I can't find VIN. Is it ok ?
  14. #13
    Your dump is not okay. Read eeprom again but as 8 bit.
  15. #14
    As said dump is not good. Don't worry about VIN as that is only in GID and CID displays
  16. #15
    Dump in 8bit
