where and when did they get it
liverpool 2 weeks ago
yeah mines done the same. got it on the 16/11/10. from ws
sometimes in transit cable socket inside box comes off the boards,have a look through vents,as removing top may stop your warranty.unplugged of course.
sv7 was working ok when it just died,no life menu nothing Cry found out some useful info that might help others follow below.
If it's def. not scart, try AV/TV button on remote.
Does LED on box flash when you press any K*y on remote.
You can try this if you like;
MENU
Hit DOWN K*y
RIGHT K*y
DOWN K*y twice
OK K*y twice
keep pressing OK until red LED on box flashes
thanks to eamo
yes the led flash when pressed k*y
did what you said with remote the led display has gone from the program number to 4 4 dots in the middle. please help
has the box been flashed with firmware and which one?
carling 3. but that was 2 or three weeks ago been fine just stopped on friday night. tv just comes up no signal. screen flickers as box boots up then back to no signal. any help would be great
no signal to me says signal/coaxial problem,everything in and tight.are you paying a sub?
you are great thats worked spot on thank you so much.
i love this site every time i have trouble someone helps me.
thanks again happy in nottingham
cacti you are a star the stuff you put on worked teat menu back on up and running you are a wealth of knowledge sorry didnt get back sooner only digi kaos was down and had no accsess
not just me we all try to help others and that extract was from eamos post.if we can we will as others have to read.
REVIVAL. what ever that is but its great thanks again
