Results 1 to 13 of 13
Thread: sound issue
    DK Veteran clem58's Avatar
    Aug 2009
    Belfast
    Default sound issue
    I have a video on my pc, the sound quality is fine but as soon as i copy it to my hdd or mem stick, the sound is gone. can any of you guys tell me if its possible to rectify it. Is it possible that i'd have to transfer the file. Thanks for replies in advance.
    xant14's Avatar
    Dec 2008
    Mental Mowbray
    more specific please...
    You have a video file on PC??
    .avi .mkv .mpg or what?
    and you transfer same vid file, and it wont play sound?
    little more info please.
    Aug 2009
    Belfast
    Its an avi file, but i'm not sure the problem is specific to that one type of file.
    Dec 2010
    Default sound problem
    Hi,If its an avi or mkv file the usb pen you are using could be corrupt?give it a full format or evan test the usb drive with testing s/w free courtisy of google.
    Aug 2009
    Belfast
    I thought that two, but i get same result whether i stream, use mem stk or hdd. yet it plays perfectly on my laptop.If i transfered the file instead of copying would it make a difference. The file transfer is something i've never done, i've copied everything up to now.
    Newbie lexxspam's Avatar
    Mar 2010
    try Gstop codex going give all info on the file Free-Codecs.com :: Download GSpot 2.70 : GSpot identifies which video codec and audio compression method is used so you know got right codex for it to play
    xant14's Avatar
    Dec 2008
    Mental Mowbray
    Strange. What player are you using? Have you tried other players?
    I find VLC player one of the best, in fact I use it for everymovie file unless it is a massive file which I use XBMC live.
    VLC can be had at VideoLAN - VLC media player - Open Source Multimedia Framework and Player
    Jan 2009
    Post
    im agree with billybongo11 theres somethink corrupt on there
    thats causing your issues proberly a driver or codec
    remove your sound driver and then reinstall *maybe update if possible*
    remove all audio codecs then reinstall them
    also if you have your disc installed with
    your operating system
    (you will need an administrator account for this)
    xp
    put disc in
    go to run
    type sfc /scannow
    let it scan
    windows 7
    put disc in
    on the start search and program files box
    type cmd or command prompt
    right click on on it go on run as administrator
    or run as another and type in your user info
    then type sfc /scannow
    then let it scan.
    Aug 2009
    Belfast
    I will look into all of the above,but reapers post is something i'd be keen to learn about. It would be something i've never had to do before. thanks.
    Aug 2009
    Belfast
  11. #11
    xant14's Avatar
    Dec 2008
    Mental Mowbray
    I never load ANY codecs. I simply throw ANY file at VLC and it plays em. Why makes things complicated???
  12. #12
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Download klite codec pack.
    Free-Codecs.com : Download K-Lite Codec Pack 6.6.0 FULL, K-Lite Codec Pack 6.6.0 STANDARD, K-Lite Codec Pack 6.6.0 BASIC : K-Lite Codec Pack is a collection of codecs and related tools
    Also, if any player is not playing the file, look into your sound device drivers/speaker config.
    So any mp3s play? are your speakers setup to correct setup?
  13. #13
    Aug 2009
    Belfast
    I'll let you know how i don't get on.
