Hello!
I need to make immo off on this ECU (Berlingo 1.4). The thing is that it does not have 28F256 or 27C256, but has 29C512 memory. Which wiring diagram do I have to use in order to read TMS with XProg-M? Thanks!
Hello!
POST ME THE VIN AND I GEV YOUR PIN CODE
I don't have immobox anymore, I am already using decoded ECU on this vehicle, but it was damaged by ignition coil so now I have to replace it. Thanks anyway.
Has nobody done immo off on this ECU before?
You must Read TMS374 and send dump ! Tiniswaper or other methode not work !
Jerry15 (26th August, 2016), jovial (15th June, 2016), Renovator (30th November, 2020), Stelaras26 (20th November, 2019)
I test you solution and not work ! Car not start ! I write Clean Dump to TMS374 and Car start OK !
I use ETL Programmer and external adapter ! I had to remove the processor and program it !
Hi Magdex, What ETL do you use with your TMS, I need more precision because I must do the same, take an another SL96-9 for testig your solution because with sagem coil, ECU is damaged....
Thank in advance.
look this file..
Cesarec (5th November, 2018), condorneck (7th November, 2017), Hayssam1 (25th October, 2022), hbalazs (15th February, 2024), jovial (15th June, 2016), Keyelec (8th May, 2024), latino (13th April, 2022), luchito (4th October, 2016), MARIKO (9th December, 2023), mnem (16th November, 2019), NKTA (15th July, 2021), pedritos (24th March, 2022), pedrodiaz (4th February, 2019), phantom82 (30th September, 2018), putodaserra (6th April, 2020), Renovator (30th November, 2020), tedmoh (28th November, 2023), yahia1908 (9th November, 2020)
Manual is in the language of my country Brazil! If this post was helpful do not forget the thanks button
Caarlosalfredo (10th August, 2020), carlab237 (25th June, 2020), Cesarec (5th November, 2018), condorneck (9th April, 2018), hbalazs (26th August, 2019), jovial (15th June, 2016), Keyelec (8th May, 2024), line44 (10th September, 2020), luchito (4th October, 2016), mancinofranco (2nd December, 2016), MARIKO (2nd May, 2017), milerk (10th June, 2014), nelumuresan (29th March, 2018), Pzolee (25th March, 2016), Renovator (30th November, 2020), sapopt (18th May, 2017), tedmoh (28th November, 2023), zecozc (5th October, 2016)
^^ This did not work for me. However, shorting pins 1A-1B ... to 9A-9B by sliding tweezers over EEPROM's legs did the trick. It just takes some patience, it took me about 5 minutes of "tweezer sliding" and car started. If you don't know the exact procedure, search for thread about Renault's ECU "Fenix".
CIRCUIT.FR (20th November, 2013)
