I just purchased STAR2000 COMPACT3 FOR MERCEDES-BENZ with Xentry2010.03 ,but I cant manage to get it work yet.
I set the COM 2
Bits per second: 115200
Data bits: 8
Parity: None
Stop bits: 1
Flow Control : None.
I tryed many times without succes. I open the adapter of PC serial cable and I see wire unsoldered .Inside the adapter I see PCB with MAX232.I solder the cable , try the cable on another DAS diagnose and it dosent work.But the other DAS original its PC serial cable was without adapter on the meadle of cable.
Did anyone tryed both versions of serial cables with and without adapter on MULTIPLEXER ?
