Results 1 to 2 of 2
    Default BMW E60 US DRL coding
    Anyboby knows how to code US DRL (high beam at low intensity) on E60 ECE with NCS Expert by FSW_PSW manipulation like it was possible in older models e39/e46?
    For E60, I do not know what parameters I must change in FSW_PSW.
    Many thanks for inputs.
    Thumbs up
    Use the almost similar FSWs as for older cars. To change just two of them in E60 LMA is enough for US DRL top work, the same like in LCM3 & 4 of E38, E39 and E53 (old cars described by e.g. KamilFKH?s thread on Czech BMW club).
    One FSW for setting of bulbs dimm factor, other FSW for switching US DRL on. Do not be mistaken for nicht_aktiv PSW for the second FSW. It is not to be changed to aktiv, but with
    - wert_01 sets Blinkers (turn indicators at 4Watt - 18%) ON,
    - wert_02 sets US DRL (high beams at 10Watt - 18%) ON
    Search for DRL in FSW got from LMA only and You will find the two proper FSWs to change.
    Cheers, suicyco.
