Results 1 to 5 of 5
    DK Veteran daz24c's Avatar
    May 2008
    Stockton on Tees
    Default file or directory is corrupt and unreadable
    hi ive got a folder that i cant get rid of on my external hard drive.when i click on it i get an error msg saying its corrupt and unreadable.i cant delete it or do anything with it.does any1 know how to get rid without formatting the hard drive?
    Thank Me If I Help You
    dasteph's Avatar
    Nov 2008
    north east
    Quote Originally Posted by daz24c View Post
    you could try backing up all the files barring the corrupted file then formatting the hd to remove it.
    Jan 2009
    i agree with dasteph backup first before you do anything to make
    sure the data is safe.
    you can use file assassin to remove the file from your computer
    portable edition
    http://www.malwarebytes.org/FA_Portable.zip
    might also want to look for bad sectors on your hard drive.
    these will guide you
    Windows XP
    Check for Disk Errors in Windows XP
    if your running windows7
    How to use CHKDSK (Check Disk) - Windows 7
    Dec 2010
    try to rese recover my files if there is any important files ,
    then format it , you may have a bad sector on it
    May 2008
    Stockton on Tees
    Thanks for the help i just put everything on another hard drive n then formatted it to get rid!sorted now
    Thanks!!
