Results 16 to 30 of 36
  1. #16
    Huy Guys
    Please any body tell me the Description of thees codes :
    PID 084, FMI 09, 0
    PID 084, FMI 11, 0
    SID 230, FMI, 04, 0,
    this is very important for me ,
    thanks in advance .
  2. #17
    america del sur
    Quote Originally Posted by hanzem evr View Post
    Huy Guys
    PID 084, FMI 09, 0
    PID 084, FMI 11, 0
    thanks in advance .
    hello friend Hazim: VCADS pro install after putting the keygen and enter the files with a click accept and then to mark up items just makes you want to see models and down these T1 and V22 will give you all the functions then buton and then do it let me know as I was greeting
  3. #18
    thanks mate the problem solved .
  4. #19
    I join the request. Please explain in detail.
    Thank you.
  5. #20
    america del sur
    Quote Originally Posted by sova View Post
    Thank you.
    first install the program either 2.35 VCADS restart the computer after you open the crack VCADS you click on the setup after then take l window open after VCADS kg active there first of all if you want above and below T1 and then press button 2 V22 from there you give doit and ready so it works but does not move me one diagnostic parameters
    excuse my bad English I'm using the google translator
  6. #21
    any buddy share VOLVO IMPACT ??
  7. #22
    Member ddtech's Avatar
    Dec 2010
    buddy i got this error as well the solution to my com error was that when you install hino and its com adapter install files it interfers with volvo vcad!!!!
  8. #23
    Dec 2010
    hello
    please help me
    vcadspro 2.35 instaltion and crack with old interface
    thank you
  9. #24
    hi guys
    Please any body tell me what is this codes mean???
    i don't have impact or DTC guide . and what is (road speed )where is location in vehicle ??
    thanks mates
    this truck is volvo fh12 the problem with Engine RPM when ne
  10. #25
    Dec 2010
    hey man i got a question does volvo vcad 2. 35 work with nexiq usb link???
  11. #26
    Quote Originally Posted by ddtech View Post
    yes it is work like a charm
  12. #27
    Dec 2010
    do you run it with volvo ptt vcad or just vcad pro 2.35?
  13. #28
    Cincinnati ohio
    No this is just vcads 2.35
  14. #29
    Default help
    hey guys i need some help. i have been following the instructions to install vcads 2.35 and when i use the key gen i get these messages
  15. #30
    Dec 2010
    i buddy you got this error beacuse you updated your vcads!!! never update it
