Page 1 of 2 12 LastLast
Results 1 to 15 of 18
    florinyes's Avatar
    Dec 2009
    London Middlesex
    Default Megane 2000 dash
    can someone help modify this dump?
    Has 139999 now need 78100? mcu hc08az32
    Cheers
    Whatever seems impossible is just not yet important enough.
    adam28's Avatar
    May 2009
    UK Essex
    Need your Dump mate. Think you forgot to upload.
    florinyes's Avatar
    Dec 2009
    London Middlesex
    uploaded now
    is this ok?
    Updated All good thanks
    drpeter's Avatar
    Dec 2009
    The Netherlands
    Quote Originally Posted by florinyes View Post
    uploaded now
    is this ok?
    Matey don't you have a diga clone?
    Renault Scenic 1999 Jaeger cluster
    menu Clio II, Jaeger 908 diag., cable 912, gray cluster connector red pin 16, green pin 17 and black pin 24 and it works without soldering and removing the needles
    Easy fix
    florinyes's Avatar
    Dec 2009
    London Middlesex
    Too late mate..done it the hard way...I don't trust diga..
    Got another grand cherokee in now and really not sure I want to plug diga in any more..
    I've had grief in the past..
    Thanks anyway for the heads up!
    Nov 2009
    celje, slovenia
    i have just done 3 jager clusters vith diga. best renault cluster, and easy money
    V.I.P. Member milanoffracing's Avatar
    Jul 2009
    Bulgaria,Sofia
    uploaded now
    is this ok?
    I think your file is not ok, try this one.
    florinyes's Avatar
    Dec 2009
    London Middlesex
    Quote Originally Posted by milanoffracing View Post
    My file is OK...78100 car gone
    Cheers
    Nov 2009
    Poland
    This dash make interface on max232 and this soft, but I use win98 to this soft and work 100% but I heard that work on winXP, too.
    Nov 2009
    Poland
    Soft for jeager
  11. #11
    Nov 2009
    Poland
    soft for jeager, I don't have add soft
  12. #12
    Nov 2011
    Macedonia
    Quote Originally Posted by bodzio012 View Post
    Do you have idea where i can buy?........max232
  13. #13
    smokey08's Avatar
    Mar 2010
    Essex, UK
    Quote Originally Posted by baze007 View Post
    Are you in the UK?
    Try here
  14. #14
    Nov 2011
    Macedonia
    Quote Originally Posted by smokey08 View Post
    Are you in the UK?
    Try here
    Thanks for your help i,m from macedonia.Does it look like this?
    MAX232 RS232 COM Serial to TTL Converter Module Board | eBay
  15. #15
    smokey08's Avatar
    Mar 2010
    Essex, UK
    No use something like this.
    connect pins like this
    Cable------------Cluster
    16------+12v-----16
    7------------------17
    4+5------0v------24
