I am running DAS 11.2010 and while trying to connect to my car I get an error message regarding connection failed. This doesnt happen right away when I connect but after DAS going through some of the "connection steps"...
Here is my Caesar selftest results:
Selfdiagnostic
Device: Part D
Toolkit-Resultcode: 1
SDconnect Toolkit - device diagnostic - Part D
CAESAR STOS+ Rev.:2.12 from Jun 16 2005
generated protocol file from 17.12.2010 20:05
SystemCheck :
Check serial ... 0 Ok
CAESAR HW Detection :
D2Access ... 0 Ok
D2DownLoad ... 0 Ok
CAESAR Part D2 detected on COM2 with baudrate: 19200
CAESAR version check :
D2CheckSNVER ... 0 Ok
User is Daimler-Benz AG
User Authentification 1
Classification 0
Serial Number 0298XX
Authorization Level 4
Part D
Hardware Authentification 011205
Hardware Date 031205
Special EEPROM check :
D2 Special EEPROM check:
Inst. date registered ... 0 Ok
D2 Special CAN Test :
Special Test ... 0 Ok
Classification 0
Part D
Slave check :
D2 Slave check
D2 Processor ... 0 Ok C165 (mask step CA) is mounted.
D2 RAM ... 0 Ok
D2 FLASH ... 0 Ok
D2 EEPROM ... 0 Ok
D2 SERCTL1 ... 0 Ok
D2 UART1/2 ... 0 Ok
D2 ADC ... 2500 Error ADC
D2 Display Power Supply :
D2 Power Battery ... Voltage KL30 = 11.3 V
D2 Power Ignition ... Voltage KL15 = 00.3 V
D2 Voltage K-Lines :
D2 State K-Lines (35) ... Total 0 (+), 35 (-)
What do you guys think? Actually, the first time I ran the selftest I did not get this ADC error. Then after applying timeout fix and trying to connect to car 1 more time and then running selftest I get the above...
Thanks.
Regards, Leo
