Results 16 to 30 of 35
  1. #16
    Apr 2009
    Hi Happy_Highlander, I'm sorry but I don't know what you mean by to "kill disk to wipe the drive clean". can you explain this to me. Thanks.
  2. #17
    happy_highlander's Avatar
    Aug 2010
    Quote Originally Posted by memyi View Post
    Kill disk is a utlity that can be found on the disk in this thread http://www.digital-kaos.co.uk/forums...cd-v11-155845/ it will wipe the drive clean of all info on it which may remove any write protection at the same time. Just a thought I did notice in one of the earlier posts you were told you didn't have sufficient rights to format.Are you logged in as administrator when you try to format.
  3. #18
    Apr 2009
    Hi Happy_Highlander, I am an administrator. This is getting the better of me now. I will try your link hopefully that will work. Thanks for the help.
  4. #19
    Aug 2010
    There are also a few password removing tools on that disk. In fact there is just about everything you will ever need on that disk
  5. #20
    Apr 2009
    Hi Happy_Highlander, I had a look at that killdisk, I tried it but was unsure of what I was doing. I'll give it another read and then try again. Thanks for your help. Much appreciated.
  6. #21
    Aug 2010
    Just make sure that you choose the correct drive letter it will be a complete ball ache if you wipe the wrong drive by accident
  7. #22
    Feb 2011
    Have you tried it in another computer it might be your settings?
    Personally if it was me i'd use a hammer and buy a decent flash drive like a Kingston with a 5 year warranty,I have lost data in the past moving stuff using a cheap one and when you plug in to usb just the folder is there but nothing in the folder just vanished!
  8. #23
    Sep 2011
    how to remove write protected on my memory stick? plz.. help help
  9. #24
    Nov 2011
    Default card format
    hi any one help me dre???
  10. #25
    Junior Member Pricley's Avatar
    Aug 2012
    South Africa
    Hi Guys
    I also have a write protection issue on my memory stick, I have not formatted it because there is some information that i need and have not backed up before this issue arrived.
    Is there any way of doing this without formatting?
    I have tried the program on zip file but it say no disc detected, or something like that.
    Thanks in advance
  11. #26
    Aug 2012
    South Africa
    Any who can lend me a hand?
  12. #27
    Oct 2012
    Please help me to format my write protected mmc
  13. #28
    Dec 2012
    Default write protection
    can any1 tell me how to remove write protection from memory card.... I've tried all above mentioned steps... helpless... kindly help me in this....
  14. #29
    Oct 2012
    Northern Ireland
    Hi guys, I bought a 32gb memory stick online. It seemed to work ok for documents, music and photos but through my media player or laptop I could not playback any movies from it even though the movies seemed to transfer ok. Now transfering files is a problem "write protected" pops up when I drag and drop files into it. Any ideas as to remove this "write protection " from my memory stick. I can't remember doing anything for this to have changed. Thanks in advance.
    Kept happening to me on a 16gb. Couldnt get it working. Untill trial and error kicked in..........
    I simply removed it from one USB port to the other and it worked for that session. Reboot and the write protect came back.
    Weird thing is. It doesnt do it on any WIN7 x64 machines ive used.
    When your posting your USB stick or MMC card faults, could you post your version of windows with it? As in for example Win Vista x86 etc......
  15. #30
    Oct 2012
    Glad you got your problem sorted Frogger.
    BUT
    DO NOT BUY CHEAP FLASH DRIVES FROM CHINA
    Having lived out there last year I can tell you the place is awash with fake capacity drives - and they are getting pretty sophisticated as well, installing custom chips that fool many of the diagnostic programs used to detect fakes.
    There are even fake SSD drives, which are empty except for a chip and a small capacity sd card inside.
