could also give iport a try and if you can connect to the box telnet or use flash wizard.
XeroxUk, I have got the same issue like yours.
I have tried all the ways with different dreamup version and different images, but same msg even with the patched dreram box.
When I attach the box I get this this:
19:15:24 box type: DM500
19:15:34 Ping result: OK, box is alive and speaking to us ;-)
And then I flashed with erase.img, I get this:
Box was flashed sccessfully!
19:16:38 Uploading file to box...
19:16:41 calculating CRC32 on STB...
19:17:08 erasing flash...
19:17:10 box is flashing from its memory...
19:17:15 calculating CRC32 on STB's flash...
19:17:15 "flash erase"...
19:20:36 OK, flash-copy succeeded
Now I flashed the original image, after a while comes this:
ERROR,upload aborted!
Is the box still working or dead???
Help pls!
thx.
Finally, I got it working!!
Firstly, I i used patched DreamUp to flash the box with erase.img (I did twice) then without disconnecting I patched pliJade image and it went through.Connecting to tele and works fantastic.
Thx to all!!!!
I guess the DreamUp updated version, detects pirate dreamboxes and that is why it refuses to work correctly.
I have the same problem, with USB-COM cable and Windows 7.
I had exact problem with the error aborted by user
its due to the version I was running. The attached verison 2.1.5 works perfectly for me
Spodge007 (15th March, 2014)
the archives is either in unknown format or damaged
please send me another thaank
Best regards aissa
AISSA SERVICE ELECTRONIQUE
BLIDA car radio decode
I bought my dm 800hd pvr and 500 at dreamboxcom.com. Is it clones?
i need an erase.ing to try it pls help me
here mate good luck
Where to find patched version dreamup ?
different version of dreamup worked for me too
