Results 1 to 12 of 12
Thread: XPROG-M problem
    DK Veteran andrym3's Avatar
    Default XPROG-M problem
    Hi guys, I have a problem with my xprog-M (hardware voltage too low ), when i read mcu or eeprom.I used RS232 cable and external power supply 12V
    diagnoza_auto2000's Avatar
    Sibiu
    Quote Originally Posted by andrym3 View Post
    Change you external power with another ,use bether 15 V
    Thanks,but it's the same problem
    Holtek's Avatar
    Replace the capacitor marked in the picture.
  5. The Following User Says Thank You to Holtek For This Useful Post:
    RUSLAUTOEL (14th November, 2017)
    roth18's Avatar
    US
    There is a thread about XprogM clone, it looks like the green board clones are better than the blue ones. Also, there were some repair procedures to repair the blue board XprogM clone.
    Use search.
    Best Regards, Roth.
    See in the picture the test result .Thanks
    Holtek's Avatar
    Is yellow tantalum are not broken? Have you changed the capacitor? Voltage on the first pin IRF7316 is too low. It should be about 17V. Check the voltage on the B0505, as I mark it on the photo.
    Thank you for your help, I think the problem is from the DC/DC converter regulator B0505, there are only -3V at output ,pin4 compared to ground is 2,3 V instead of 17V.
    B0505 voltage recommended
    Pin 1 & 2 = 5v input
    Pin 3 & 4 = 5V output
  10. #9
    Holtek's Avatar
    Maybe the DC/DC converter is overloaded. Load of the DC/DC converter is the first pin of the IRF7316. Lift it and see if the voltage is changed. If the DC/DC converter still does not work properly it needs to be replaced.
  11. #10
    cipijoint's Avatar
    i have this problem too, with or without the power supply conected.
    I tried other xprog, not get this error, desnt matter if i have or not power supply .
    So, problem its not from the 12v supply .
    dont talk a lot and nothing
  12. #11
    Sep 2022
    Hallo. I solved this poroblem. Connected this pin to GND
  13. #12
    Jul 2016
    I need software for xprog-m ver 5.0 and solution repairing my xprog when update deaded and not working only when connect to pc and command to software white led lit .and other 2 led(green and red)not lit.
    Thanks.
