Results 1 to 15 of 21
Thread: EDC16 no power
    florinyes's Avatar
    London Middlesex
    Default EDC16 no power
    Hi guys
    got this one in tryed to bdm it to remove DPF and connected ports the wrong way round...the 5 pin line with power on the opposite side..
    Now the ecu won't power up..can't even read it with Bdm...
    Anyone knows if there's a fuse that blows (within the ecu) if powered up wrong?
    Biggest problem VW have non in stock and customer needs the car for holidays..
    regards
    Whatever seems impossible is just not yet important enough.
    Elsewhere
    There is no fuse inside the ECU.
    I saw once a car the owner connected the battery opposite ( inverted polarity ) the ecu on the car, one fuse burnt.
    Car ( normally ) didn`t start. Connected battery correct, change fuse, ecu escaped well, car worked.
    But with ecu on the table , no fuse, inverse mains, my opinion ecu = burnt
    Hope I am wrong but you must find an ecu repair guy.
    carmageddon's Avatar
    Italy
    Quote Originally Posted by florinyes View Post
    Hi guys
    regards
    hi
    when reversing the polarity will damage the mpc and the ECU will not work.
    the only cheapest and faster solution is replace the ECU with an equal.
    you can find many ECU on ebay simply by writing the HW numberin search men?.
    exxl's Avatar
    Jun 2009
    Bosnia-Herzegowina, Bos. Krupa
    processor is burned out, search for a new ecu
    Ireland
    Quote Originally Posted by exxl View Post
    What number ECU????
    florinyes's Avatar
    London Middlesex
    Quote Originally Posted by robert54 View Post
    What number ECU????
    top of my head: 3D0 907 401 A also has another number on it..8E0 907 401 AB don't know why??
    Find this on e bay but for an audi and bosch number not the same..AUDI A6 3.0 TDI ENGINE ECU 4F0910401FX 4F0907401A NEW on eBay (end time 15-Jan-11 13:32:40 GMT)
    Wish it'll fit..
    Italy
    find on google or ebay the ecu with bosch HW number...the number start with 0 281 ... ...
    for the electronic configuration its better to have minimum the same HW number.
    VENICE
    look this photo
    florinyes's Avatar
    London Middlesex
    Very rare the one I have...or I can't find same HW no.
    I would've thought similar vag part number for ame engine code (BMK) will do?????
    florinyes's Avatar
    London Middlesex
    Quote Originally Posted by risalelettronic View Post
    look this photo
    I know how bosch part no looks like,....but I thought vag number will a reference point?
    HW number has to be 100% similar?
    Italy
    different hw nr may compromise diagnosis and electronics configuration...i do not know if everything is working correctly because the hw nr is stored in each ecu on board.
    I substituted ecu on two vag but always with the same nw number and everything was fine.
    Italy
    can we know hw and sw number of this ecu?
  13. #13
    florinyes's Avatar
    London Middlesex
    HW 0281 013 677
    Not sure about SW number as ecu is at work..
  14. #14
    Italy
    effectively the ecu can not be found online.
    Tomorrow i try to ask two companies if they have the ecu in question.
    please send me details of the car
    Brand
    Model
    Registration Year
    kw / hp
    manual or automatic transmission
  15. #15
    florinyes's Avatar
    London Middlesex
    Cheers
    Car is a VW Phaeton 2007 3.0 V6 TDI 225 bhp.
    Where about are ya?
