Results 1 to 15 of 19
    Default ECU 318tds tunning
    Hi world, i have a ecu DDE2.1 bmw e36 318tds m41 bosch 0 281 001 711 and i want to make tuning. What memory is that? I'am looking a map too.
    Many thanks...
    Dec 2010
    Take a look inside the ECU, possibly 2x 27c256 but some are through hole soldered and not in sockets
    DK Veteran obnchip's Avatar
    Dec 2010
    Quote Originally Posted by nanico View Post
    Many thanks...
    Hi!
    You can try...
  4. The Following User Says Thank You to obnchip For This Useful Post:
    leandroks (24th April, 2018)
    Dec 2010
    Many thanks...
    use these i missed pump voltage map...
    Default 0281001711 = 0281001243????
    Now I'm confused. I opened the ECU and found two EPROM No. 0281001280(1) of board 0281001243.
    Maybe the board was replaced.
    The eprom are the same 2x 27c256 as 0281001711?
    Many thanks
    What is the increase in power does this firmware?
    I have tested it. About 20hp, its a very good one.
    Aug 2012
    Polska
    both EEPROM write because I have to? or can be replaced in the 658?
  10. #9
    Aug 2012
    Polska
    658 and 659 exchanges, or 658?
  11. #10
    Dec 2010
    only 658............
  12. #11
    Aug 2012
    Polska
    with the contents of a very high idle. Does anyone have a good one?
  13. #12
    You resolve the problem with high idle? I have the same problem.
  14. #13
    Dec 2010
    i have done this version also
  15. #14
    Oct 2016
    World
    Quote Originally Posted by obnchip View Post
    do you know what is the other 3 unnamed maps?
  16. #15
    Oct 2016
    World
    There is one untouched smoke limiter map at 07D20 , and whole power goes from raised quantity adjuster map. Correct me if I'm wrong.
