Page 4 of 4 FirstFirst 1234
Results 46 to 60 of 60
  1. #46
    Feb 2011
    While the crack seems to work, if you are using this software to tune a car and log data it doesn't work 100%. With the cracked version you get erratic or wrong data ever 5-8 frames on refresh. If you record or monitor a vehicle key on engine off you rpm will start at 0 then ping to 1500, 4000 and even up to 8000+ rpms along with all the other readings TPS, fuel trims, etc.
    In the evaluation version from the palmer website the RPM will datalog rock solid
  2. #47
    Yep, I notice that too. There is a problem in RPM reading(Live Data). Hope we can get better crack/medicine very soon.
  3. #48
    If you roll the date back on your computer to about the same date you have installed ScanXL, it will work correctly.
  4. #49
    Default Program to help scanxl
    I use a program called runasdate, it's easy to find and works well with Scanxl.. It stops the erratic data issue, just use runas date and creat a shortcut with a date the next day after the install date of scanxl..
  5. #50
    Jan 2011
    Thanks for the software but I do have one question. I don't know where to find/download the GM enhanced add-on? Could someone show me where it is? Or is the add-on built in to the pro version and getting a specific licence opens that feature up ? Please clarify.
    Thanks again for the software and in advance to whoever clarifies my question.
    PS: Which interface does one recommend for this software to work correctly with a 2002 GMC Sierra 2500HD Duramax Diesel to scan everything.
  6. #51
    sweden
    i like L?fbergs kaffe b?ttre :-)
  7. #52
    USA
    please upload again
  8. #53
    is anyone able to re-upload it?
    Also looking for Dashcommand (more then scanxl)
  9. #54
    Top Poster physyc's Avatar
    May 2012
    Quote Originally Posted by sanscorp View Post
    get cydia on your iphone, get installous, open installous go to search, search "dascommand" klick on download.
    Done.
  10. #55
    can anyone direct me too the crack for scanxl 3.2 , i downloader program but need crack program to to get software going thanks anthony
  11. #56
    Jan 2013
    Default Crack
    Quote Originally Posted by integlikewhoa View Post
    I use a 25.00 ebay bluetooth elm327. It sux, probley just the cheap crap I got, but its more work then I need. I want a USB one.
    I have confirmed the crack working on the new version. Even if not much diff. Might as well use the newest out.
    I recommend downloading the newest here.
    http://www.palmerperformance.com/dow...-pro-setup.exe
    And useing the crack from above.
    Friends, I must be blind but i can't find the "crack from above"
  12. #57
    reup for your convenience
  13. #58
    Member utcatmech's Avatar
    Thank you for taking time to help everyone out.
  14. #59
    456
    789
  15. #60
    Palmer.Performance.ScanXL.Pro.v3.2.0.1692-techjoe
    Download!
    A P2P ReleaseCracked by techjoe over @ digital-kaos.co.uk
    Instructions
    1)    Install program.
    2)    Copy cracked exe over into installation directory overwriting the original
    3)    Register program with the values listed in License.txt
    NOTE: Fluctuation Value Problems with this release!
    On the 24th day after the installation scanxl professional 3.2 went to fluctuations of the parameters to complete.Prior to that almost all functioned normally, including the functions of rasshipennye Ford and Mazda, except sometimes there are small random fluctuations of individual parameters. And it does not happen every day, and the magnitude of the fluctuations was less than 1% of the parameres, which practically did not influence the final result.
    Now, all spree almost on full-scale graphs. So long as there is no medication for normal scanxl professional!
    dependence of the appearance of fluctuations from time to time ustsnovki program suggested the idea to experiment with the date. Put the date early in the day - works in two - is working, and so up to seven (straight from the wind). It works! That is, setting the date before the 24th day after the installation scanxl professional can work without the fluctuations of the parameters! But the work is inconvenient, the date saved logfiles and other stored materials have to edit. Think bright minds, like "turn off" the timer that fires on the 24th day? Or someone that works fine and after the 24th day?
    Continued to experiment with the date. Set date forward, a strange pattern is obtained - in each month is a period of 20 days when the options do not jump. But no system is not visible.
    Palmer.Performance
    .ScanXL.Pro.v3.2.1-kaosdigital
    Download!
    I modified patch file a little bit so anti-virus program doesn't go crazy no more.
    1.    Install the program
    2.    Apply patch where program installed (for windows7, right click at patch and run as Admin mode)
    3.    Registered with this keys
            User: your name
            Organization: none
            Customer ID: [1234567890]
            Product Code: PS-1234567890
            license Key: UMBRELLA-1234567890987654321ABCDE
    4.    Enjoy. And Happy New Year.
    NOTE:Fluctuation Values Problem may exist in this release!
    Palmer.Performance.ScanXL.Pro.v3.5.1.2770-P2P
    Download!
    A P2P Release: Palmer.Performance.ScanXL.Pro.v3.5.1.2770-P2P
    Credits: techjoe & kaosdigital
    Instructions
    1)    Install program.
    2)    Copy over patch to installation folder and run the patch
           Patch scanxlpro.exe
    3)    After patching is done close the patch. Run ScanXL Pro.
    4)    Register program with the values:
                Note: Type any values for Name and Organisation.
                    Organization: Type_Any_Name
                    Customer ID: [*88024002*]
                    License Key: CAFEAFFF-10EF7677D5968A289E461060
    NOTE:
    5)  If you experience inconsistent jumps or fluctuation in values you will need
        to run the program through "runasdate" with the folloiwng date:
            17.06.2012 or the date you first installed it on
        It seems that the crackers have missed or cannot isolate a protection check
        once the program reaches a certain date.
