Results 1 to 15 of 20
    Dec 2010
    Default Installing DIS/SSS on IBM T30
    Hi.
    I have a T30 and DK head.
    The T30 is running DIS V56 but it is corrupt.
    I need to install/upgrade to V57.
    I have V57 iso and also EasyDIS base 44 v1.0 iso
    Can anyone tell me how to upgrade or do a re-install?
    I don't want to loose SSS/Progman which I can load by hitting space bar at boot and then typing "bootos 3"
    Thanks in advance.
    Europe
    Default dis prog image
    Try this
    restore dis and progman from image for t30
    Burd them in 12 dvds
    DK Veteran tapiru's Avatar
    Quote Originally Posted by albdiag View Post
    Try this
    Thanks m8!!!!!!!
    Can you tell me what size of HDD is needed for this?
    V.I.P. Member milanoffracing's Avatar
    Bulgaria,Sofia
    Quote Originally Posted by tapiru View Post
    Thanks m8!!!!!!!
    You need 80 GB HDD mate.
    Jun 2011
    hello to all; loving the site!
    As I know this sw. is running under SCO Unix operating system.Please someone advice me how to prepare my system before trying to install this huge material.I mean is needed to install a other OS before starting eg. XP or is enough just the blank clear an format HDD ?
    Thank in advance
    DK Veteran strda50es's Avatar
    Belgrade
    Thank in advance
    Is this what you need?
    All good things come to those who wait....
    Quote Originally Posted by strda50es View Post
    Thanks m8 for reply I'm trying for this project since this material was posted 2 years before but all time it quit cause of missing a T30 but seems now I will finish this dream.All what I wish to know more is if installation succeed do I need to do some specials settings or using this image the tool will work by himself ?
    Thanks !!!!!!
    Thanks !!!!!!
    No, you don't need windowsxp.
    Just a blank 80gb harddrive and dvd drive.
    also the 12 dvd and the cd of ghost boot disk that is already include in the archive.
    Also there is a guide file showing how to recover the ghost image.
    After recovered the image, it is ready to use.
    I've tried and it works.
    Quote Originally Posted by pesona View Post
    Thanks m8 for your reply ! Seems all I need is a good T30
    Aug 2011
    Can I use a regular laptop instead of a T30? I am guessing the only reason to use the T30 is because of the DB9 port, but a USB-DB9 adapter should work fine with any other laptops.
    Sure.You can use other laptops instead of T30.
  13. #13
    rex89's Avatar
    Not Near Tricore MCU
    hi, can you give me a type of machine which can operate from DIS IBM T30 or a tutorial explains you well detailed, because I have tried it on another machine and after copying dvd 12 I have this error on startup: Error boot failure Stage1
  14. #14
    DELL D610 works fine with DIS.
    Here you will find tutorial how to install DIS on VMware:
    How to install GT1\EasyDIS v44 step-by-step - Bimmerforums - The Ultimate BMW Forum
  15. #15
    Quote Originally Posted by rex89 View Post
    Sounds like the IBM T30 setup was not configured to boot with other HDD drivers than the one T30 is using. If you do not have a T30 (or compatible) laptop to modify the installation, you can use e.g. UBCD4WIN boot CD to fix the hard drive for your computer. Google for instructions.
