Results 1 to 11 of 11
    Apr 2008
    Unhappy Tuxbox Commander Help
    Ok I was messing about in tuxbox to try and change the rights as I am having problems connecting to pc, anyway the background colour has changed from blue to black and will not allow me to change any settings. Any ideas on how to fix this?
    Administrator
    Devilfish's Avatar
    Feb 2008
    If it's black then you are in the top most directory.
    What are you wanting to change, you shouldn't need to adjust anything. If you can't connect, it will be something to do with your network settings and not something on the box.
    Apr 2008
    I was trying to change the file permission as I have tried to connect to pc and it just won't work. I have tried loads of different passwords also tried on both xp and vista, tried different cables the lot and it just keeps telling me that the target machine is refusing connection.
    Administrator
    Devilfish's Avatar
    Feb 2008
    It's nothing to do with the file permissions, trust me.
    It's your network settings.
    What is your PC and dreambox IP address?
    How are you connecting? via router or straight to PC?
    Apr 2008
    Connecting straight to pc with crossover cable.
    Pc Ip address is set to 192.168.0.105
    Nokia Dbox Ip is set to 192.168.0.100
    V.I.P. Member Jaffa's Avatar
    Mar 2008
    Norn Iron
    IPs look fine.
    What ftp client are you using, have you gave permission for it in firewall or turn firewall off ???
    Are yu using the correct username and password ???
    Apr 2008
    your best using your pc ftp username root passord dbox
    Apr 2008
    Quote Originally Posted by Jaffa View Post
    IPs look fine.
    I am using FlashFXP and have turned firewall off so thats not the problem. I have tried lots of different usernames and passwords but still no luck. Ready just to give up me thinks.
    Mar 2008
    Norn Iron
    What image is it you have on now as Commando images use commando as the password.
    Apr 2008
    Using sportster so username should be root and password dbox or dbox2 both of these have been tried. I have tried everything I can think of to connect but looks like it's just not meant to be...
  11. #11
    Mar 2008
    Norn Iron
    Sportster password is definetly dbox2. Have your tried yweb by typing the dbox ip into your web browser address bar, you can do a lot with yweb, like flash an image
