Results 1 to 7 of 7
    Default Opel Signum 2004 , 30 dti fault code
    i have next fault codes:
    P0380 - Glow Time Relay Circuit Malfunction
    (00) - Present
    P0520 - Engine Oil Pressure Sensor/Switch Circuit Range/Performance
    (00) - Not present
    U2103 - No Communication with CAN-Bus (High Speed)
    (00) - Not present
    please help if anyone have experience with this fault codes ?
    thank you
    ( Opel Signum 2004 year, 3.0 DTI)
    DK Veteran Albanais's Avatar
    Tirana
    Measure the battery and check earth cables and charging system. Make sure that you have a healthy battery and after this deal with the fault codes
    Learn from the mistakes and live the life.
    Quote Originally Posted by Albanais View Post
    thank you ,
    i will check but i think it is not problem because battery and charging is OK and have some fault also Engine Oil Pressure Sensor/Switch Circuit Range/Performance
    will check and let you know
    Tirana
    Quote Originally Posted by davor.electronic View Post
    thank you ,
    Charging is one thing and health of the battery is one other. If periodical has been made long time a go, then change the oil filter and check for improvements. If your battery is older then two years then the health of the battery might be in question. Do this things first then take the other steps if needed
    The engine does communicate with the can-bus. Otherwise you would not have been able to read these DTC's.
    As far as I know U2103 is No communication with Gateway.
    So there's another system (the gateway) that doesn't work properly.
    Take it to someone with the correct equipment to read ALL ecu's, either dealer or someone with Op-com.
    Oct 2008
    Greece
    Red face
    (00) - Present
    thank you
    Well, for to understand HOW MUCH "Sensitive" it is this DTC, take a look on the Attachment and follow ALL THOSE 34 Steps Step - By - Step!!!
    Good Luck!
    X-Mas Regards!
    Aug 2015
    hello, i canīt download the file. i donīt know why...
