Results 16 to 30 of 36
  1. #16
    DK Veteran Grizz's Avatar
    Sep 2010
    Ireland
    if i was you i'd try another image. ive noticed that the network settings fall into place a little easier in some than others, even when i'm doing the exact same thing.
  2. #17
    Dec 2010
    Any idea on most stable image (best chances !!!)
  3. #18
    DK Veteran garry1312's Avatar
    Oct 2010
    Scotland/ Somerset
    try pli jade 3.
    also this may sound easy but make sure dhcp is set turn off your router then turn off the dreambox. turn router back on and once connected turn back on dreambox. I know this has worked for me in the past.
  4. #19
    Dec 2010
    Gents
    Have checked ethernet socket on db all looks ok
    Have placed it next to laptop and straight connected it with ethernet lead , checked belkin home page and cant see it on there . (when i ip config/all i only see my laptop )
    Also have configured a wi fi bridge and when that is plugged into db only get a solid yellow light (thought it was meant to give a blue light out )
    Really appreciate your help , all this time of work for hols and no satt is not good !!
    Garry can you explain your post a bit please
    Dave
  5. #20
    V.I.P. Member opsmonkey's Avatar
    Nov 2008
    var/etc
    why have you connected it to the laptop..???
    connect it to the router or it will never find it
    log into your router.. if the router fails to find it then either your router is faulty or your port on the dreambox is.. as you have posted this problem on 2 other sites and have had all the required info to fix posted back, if its still not working by now take it as ~~~~ed..
    reflash it with gemini 4.2 in the downloads section... flash an erase image first
  6. #21
    Dec 2010
    Have had it in router previously no good
    Had someone else box connected to my router (dcc found that)all ok
    All free sats ok just no dcc connection
    3 forums = desperation !
  7. #22
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Have you tried a differant router? Looked for firmware update for the router?
    Turn DCHP on in the box save then power off
    Power off router
    Wait 2 minutes.
    Power box
    Then power router.
    Go make a brew or grab a cold one.
    Check to see what IP you have then.
    That fails. Manually assign IP address in the box and yurn DCHP OFF.
    Power both off again
    Power back on and see if its assigned
  8. #23
    Nov 2008
    var/etc
    Quote Originally Posted by meatloaf View Post
    if you cant get the box to work in your router, but you have managed to get another box to work with your router its pretty obvious the network card on the box is shagged..
    try flashing an erase image, then download Gemini 4.2 from the download section here, if it still wont work then it's deffo ~~~~ed
  9. #24
    Dec 2010
    Cunny
    have tried diff router
    Done what you said and results are
    ip 10.0.0.97
    Netmask 255.0.0.0
    Type Lan
    Nameserver 192.168.2.1 ( same as router ip )
    Gateway 127.0.0.1
  10. #25
    Dec 2010
    Quote Originally Posted by opsmonkey View Post
    Thing is a friend took it to try on his system and said it was fine !
    Anyway to test if this is the case ?
    Or do i just bite the bullet and see about a new one
  11. #26
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Then i'd go with ops suggestion, flash and erase, if no good then netwrok card or cable
  12. #27
    V.I.P. Member Fergal's Avatar
    Aug 2008
    Cunny
    ip 10.0.0.97
    Netmask 255.0.0.0
    Type Lan
    Gateway 127.0.0.1
    Turn DHCP off and give the dreambox an ip of 192.168.2.8
    netmask 255.255.255.0
    nameserver, gateway 192.168.2.1 and dns of 192.168.2.1
    then save and reboot the box and check its saved then see if dcc connects using 192.168.2.8 or type http://192.168.2.8 in your web browser and see if you get in.
  13. #28
    Dec 2010
    Fergal
    Input details as you mentioned it would not connect via dcc , same error message .
    I also put ip into browser but that would not let me into anything ( couldnot display page )
    Dave
  14. #29
    Aug 2008
    Try flashing another image on it using dreamup and a nullmodem cable
  15. #30
    Dec 2010
    Quote Originally Posted by Fergal View Post
    oks opsmonkey suggested gemini 4.2 which is the one on .
    I will try that hoping it may install differently
