Page 3 of 3 FirstFirst 123
Results 31 to 36 of 36
  1. #31
    Dec 2010
    Gents
    using dreamup , when it tells you to turn power on db it does not respond .
    Am using com 1 , no conflicts .
    Using a cable i believe to be null modem (9 pins ) which i used to use to flash a t/mate .
    Are nm cables and serial cables identical looking ?
  2. #32
    V.I.P. Member Fergal's Avatar
    Aug 2008
    It will be a nullmodemcable if you have done your TM with it
    try changing your com port bits per seconds to 115200 and using enforcer with dreamup
  3. #33
    Dec 2010
    Gents
    have erased Gemini and flashed new image into db (Nabilostat darkstar 2)
    Still does not communicate with dcc and when i tick dhcp and reboot it brings up
    ip 10.0.0.97
    Netmask 255.0.0.0
    Nameserver 192.168.2.1
    Gateway 127.0.0.1.
    Dave
  4. #34
    Dec 2010
    Dreambox has flashing yellow light from inside .
    Does that tell anyone anything ..
  5. #35
    V.I.P. VIC
    Mjolinor's Avatar
    Jan 2009
    Burnley Vicshire
    Quote Originally Posted by meatloaf View Post
    It would tell people a lot more if you did what was suggested and posted the results.
  6. #36
    Dec 2010
    Quote Originally Posted by Mjolinor View Post
    The results are 2 posts above
