Send socket error
Page 1 of 3 123 LastLast
Results 1 to 15 of 36
    Dec 2010
    Downloads
    16
    Uploads
    Default Send socket error
    I have checked all cabkles and settings ( router and dm are the same ) Dhcp gives me strange ip address starting with 10 !! And still dcc will not connect and i get error "send socket 100972")
    Would a new image possibly sort this out
    Many thanks
    Meat
    Dec 2010
    Downloads
    16
    Uploads
    Nobody
    If all my settings and cables are correct
    Is it an image problem !
    Dec 2010
    Downloads
    16
    Uploads
    check your password and username...what image are you using?
    Jan 2009
    120
    Downloads
    16
    Uploads
    Quote Originally Posted by meatloaf View Post
    Many thanks
    Meat
    try pressing menu, then shutdown and reboot now, should sort it
    Dec 2010
    Downloads
    16
    Uploads
    Quote Originally Posted by oldsatfanman View Post
    Morning
    name =root and password =dreambox
    image is GP 4.2.0. 17.12.2007
    Gemini ?
    Dave
    V.I.P. VIC
    Jan 2009
    Burnley Vicshire
    38
    Downloads
    73
    Uploads
    Why is an IP address starting with 10 strange?
    Your IP space may be 10.x.x.x so that would be right.
    Open a command window on your computer and type "ipconfig" (I am assuming you are using Windo$e) to see what your computer IP address is then you will know if it is correct or not.
    cunny's Avatar
    Jan 2009
    The Shoutbox
    73
    Downloads
    76
    Uploads
    3
    What is routers ip? 192.168.x.x?
    Manually assign ip to box in network setting '192.168.x.192' and diable dchp
    Then test network on box
    Dec 2010
    Downloads
    16
    Uploads
    Hi Cunny
    Do you mean 192.168.2.192 in db ip address ?
    tried this and does not work
    All time i match ip in dcc and on db settings , dc will not connect
    Really starting to get beyond realms of sanity now !!!
    V.I.P. VIC
    Jan 2009
    Burnley Vicshire
    38
    Downloads
    73
    Uploads
    Have you checked the IP of your own computer. You need to make sure the IP of the dreambox is correct. The easiest way to do that is to open a command window and type "ipconfig" there is absolutely no point in trying to do this randomly you need to do things in the correct order then people are not left guessing in the dark.
    cunny's Avatar
    Jan 2009
    The Shoutbox
    73
    Downloads
    76
    Uploads
    3
    MJ Is right, but another way is to manually assign the IP of the box.
    Most will be assigned along the lines of 192.168.x.x In router settings, see what the starting range is of the IP addresses, usually follow on from say:
    Router : 192.168.0.1
    PC : 192.168.0.199
    Laptop : 192.168.0.192
    I have my dreambox on a manually assigned IP of 192.168.0.194 with DCHP disabled. If you notice that the all IP addresses are the same, only the last 3 digits are changing to aviod IP conflicts on the network.
    You can see what devices are connected to the router by logging into the router and usually under a status page. If not there, reboot router, still not there then you need to sort out you IP addresses on the network.
    Dec 2010
    Downloads
    16
    Uploads
    Cunny
    Settings from router home page
    Router is 192.168.2.1
    My wireless laptop ends in 2
    wifes p.c ends in 3
    kids pc,s ends in 4 and 5
    tried using 6 for dbox = no good
    Also in Belkin router settings page it does not pick up ip for dbox !
    When searching with dcc it only pics up router and one of kids pc,s not all ip addys as in Belkin router settings page ...
    V.I.P. VIC
    Jan 2009
    Burnley Vicshire
    38
    Downloads
    73
    Uploads
    The cable from your dreambox to your router is either not plugged in or it is knackered.
  13. #13
    V.I.P. VIC
    Jan 2009
    Burnley Vicshire
    38
    Downloads
    73
    Uploads
    If you set the dreambox statically then you should not use 6 or any other that is in the DHCP range of the router, you need to use one at the top end really so that the router does not DHCP the same address to something else.
  14. #14
    Dec 2010
    Downloads
    16
    Uploads
    Have tried 2 cables and wifi bridge still get no signal
    Also just tried ending db ip address with 80 not connecting either .
  15. #15
    V.I.P. VIC
    Jan 2009
    Burnley Vicshire
    38
    Downloads
    73
    Uploads
    Plug the ethernet cable into your PC, see if that still gets served and works OK.
    Do you have a crossover cable, if you do then set static IPs in teh dreambox and the PC and see if you can ping hte Drembox from the PC.
    If you do nto have a cross over cable but you do have a hub/switch then use 2 non-crossover cables and connect the PC to the dreambox through the hub.
    Put the laptop where the dreambox is and see if the laptop works OK (that will test that the network card on the dreambox is working OK).
    Using tuxbox commander in the dreambox run the "ifconfig" command to make sure that the network config on the dreambox is all as it should be. You can also run the ping command from tuxbox commander to see if it can ping your pc and your router.
    Look in the ethernet socket of the dreambox, make sure nothing is bent in there.
    Lots more things you can try and really trying 2 different ethernet cables doesn't prove much, you need to make sure they are OK elsewhere.
