Results 1 to 4 of 4
    Dec 2008
    Default dreambox 500s stuck
    Hi mate my dreambox 500s was working fine and suddenly gone off i switched off and switched back on again but nothing happen its stuck on green light.my remote is not working either any help appreciated thanx.
    Sep 2009
    Quote Originally Posted by manif View Post
    Probably a reflash will sort it out
    Newbie gosatian's Avatar
    Dec 2010
    Tenerife
    You said you turned it off and then on again? Did you pull out the power lead as well?
    DK Veteran piopat's Avatar
    May 2008
    the image may be faulty or corrupt ,get the same image from another source ,then open dreamup and before flashing the box look just above where it says flash (you will see flash erase ) click on flash erase to get rid of the old image and then click on flash and flash the box as normal.
    i love it when a dreambox comes together.
