Results 1 to 3 of 3
Hybrid View
    cipijoint's Avatar
    Dec 2009
    Default BMW Dcan pcb schematics+ hex for your vag hex can
    for those who are curious how looks a dcan .
    all of them contains atmega 162, sure very similar like a vag hex can.
    PCB + schematic + flash atmega 162+ usb ept for mprog attached.
    If you study and modify a little your vagcom can have a dcan at home.
    unfortunately i dont know the right the fuse bits for atmel.
    I programmed with this flash few years ago a Vag hex can, but interface was becoming very hot and led red all time,something was in short to + with this flash, so for sure your hex can needs hardware modifying.
    Beeing lazy i preffered to buy ihar dcan that time ..
    dont talk a lot and nothing
  2. The Following User Says Thank You to cipijoint For This Useful Post:
    YayDoGeN (30th January, 2016)
  3. #2
    ipejasinovic's Avatar
    Jun 2009
    Bosnia & Herzegovina
    OK, but do you know what this is? And are you sure 100% that this works as D-CAN Device?
    Hint: USB-CAN Bus
    Galletto 2012 v54 full with JTAG and Mini available
    Big Stars never dies:
    Colin McRae (1968 ***8211; 2007)
    Richard Burns (1971 ***8211; 2005)
    Georg Plasa (1960 - 2011
  4. The Following User Says Thank You to ipejasinovic For This Useful Post:
  5. #3
    cipijoint's Avatar
    Dec 2009
    yes sure I know, from mictronics is it indeed.
    but files are since 2 years ago . now from that website there are not anymore ,changed and i think not to downloads available.
    Ive post the same few monts ago in garrage area that now its closed to me.
    I posted again in this area for people around here.
    I think it works ,but only not sure if 12v signal ignition on/off its forwaded to usb
