Results 1 to 12 of 12
    Sep 2008
    Default Softmod Wii and Logitech Microphone
    I have a 3.3E Soft Modded Wii - I also have a Logitech Wii Microphone - however when I play Disney Sing It I am informed Microphone not detected.
    Is this due to my Wii being soft modded
    I know Micrphone works, as when I plug it into the PC it is detected.
    V.I.P. Member ck-ok's Avatar
    nottingham
    Quote Originally Posted by jfish View Post
    what loader are you using?
    Sep 2008
    Quote Originally Posted by ck-ok View Post
    USB GX Loader set it to use IOS222 when loading game
    nottingham
    is it one of the wireless ones?
    you could try downloading the latest hackmii installer and install usb2 using homebrew channel to launch it.
    Sep 2008
    no its the normal wired Logitech Microphone
    nottingham
    have you tried 223?
    also use hermes 222 installer v4 to install 222 as ios38 and 223 as ios37 merged with ios38
    Sep 2008
    is the issue due to an external USB drive already plugged in and therefore an additional USB device on the other USB port isnt recognised
    can I not plug in one of them 4 port USB hubs and connect both USB External disk drive and microphone to the USB hub and therefore technically only use the one USB port on the back of the Wii
    nottingham
    yes this often works
    I've go the same problem although my Wii only has the mic plugged into the USB - nothing else.
    Here's the spec of my Wii...
    Wii v.4.2e
    Homebrew 1.0.6
    IOS 61v21.29
    I set this up with a tutorial I found about a year or so ago and it's worked fine since, but when I've tried any singing games, I can't get it to recognise any mics.
    Should I be trying different loaders and if so, which ones?
    nottingham
    Quote Originally Posted by mikiec View Post
    Wii v.4.2e
    Homebrew 1.0.6
    IOS 61v21.29
    launch backups with 222 or 223
    OK, been doing a bit of digging and this is where I'm up to...
    I've been using Neogamma, but apparently this doesn't work with karaoke games (apart from a particular method which wasn't recommended) so I've downloaded and installed Hermes v4 with 222 and 223.
    All OK, except that everywhere tells me to launch the games in uloader but it's not appearing in the HBC. What am I doing wrong?
    Sorted now - the tutorial missed out the bit about putting uloader into the apps directory of the SD card.
    All working OK.
