Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
  1. #16
    @ sergej
    First we must find software that let us to read flash memory of LPC9107. I don't know does Flash Magic can read this chip, but for sure can program it.
    If somebody was renumber S/N GAG file and it was work, we also can try to do it.
    Post 454 - diagnoza_auto2000 wrote "S/N is easy to change by flashing the unit,but there are solution for change sn in software too,and to crack too but a little dificult."
    Where are that solutions?
    About CRC calculation in LPC9xx
    http://www.flashmagictool.com/assets...alculation.pdf
    I regret that I can't try with my own Diagun, but actually I don't want to loose warranty by disassembling unit.
    @ baner
    Exactly, it's typical serial connection cable that used for old mobile phones etc.
    But for sure that symbol beside connector isn't symbol for serial connection, but for OBD2 standard. Maybe also it's usable for serial connection with LPC9107 by muliplexer inside Smartbox, or not used pins in OBD2 connector are used for serial connection but it's only my supposition.
    OBD2 pinout is here:
    On-board diagnostics - Wikipedia, the free encyclopedia
    It seems that pins 8, 9, 12, 13 are not used in OBD2 transmission, and maybe serial connection use them.
  2. #17
    Default LPC9107 read info.
    The following are for your information only.
    The chip was removed from the board to read.
    Results were not very promising.
  3. #18
    Thanks for info. It seems that flash memory is protected. What programmer used to read?
    And anybody has some ideas?
  4. #19
    DK Veteran sergej's Avatar
    Latvia,Riga
    On Diagun without chip and see message.If no message
    S/N in another chip.
  5. #20
    It's some idea, but we don't know this chip is responsible to other thing than only S/N, and maybe after desoldering it, Diagun will not communicate with Smartbox.
  6. #21
    Latvia,Riga
    In this chip no S/n and if On without chip you see it.
    See way bluetooth module or USB from cable connector.
