Results 1 to 15 of 25
Hybrid View
    Aug 2009
    It could be done online,..but it takes more than 5 min!
    What about 30 minutes,...and first you must wright the EHS number manually,...then to program the ETC module with the present software,..to code it,...then to program the engine ecu with the present software,..to code it too,..and
    at the end you have to adapt your gearbox on the road!
    weltune,..please take a look at correction programming menu,..in normal DAS,..forget development menu!
    Good luck!
    Quote Originally Posted by weryo View Post
    Good luck!
    can you please advise on how to write the EHS part number manaullly to the new unit as i have been trying without success for a day
