I read something about the handbrake light switch. When this is activated the ESP is not working. I don't know if this is thrue.
Hi M8 s
I have a tricky question...for the real pro s here...
If i wanna turn off ESP BY Button,it turns on again from it self...
So i wanna disable ESP by one only button push until turn off engine and on again...
It should be possible...ROTHE motorsport ask 200? for that...
But i dont check how they do...and have some other friends with G6.:R and Scirocco .:R...so they wanna all be able do ESP off on request.
Any help is apreciated.
Y
Best regards.
the golf6 2.0tdi have a bouton to switch off esp
this bouton switches to GND for central ESP
by pin13 so without gnd the esp central is off
to make it on you must buch bouton
If you have an error on ESP/ABS system this system it is disabled.
Try to simulate an error, for example open circuit for one wheel speed sensor and ESP will be disabled.
try to hold the button for longer time. if you just press once without holding system will automatically become active again.
this works on the dyno
what exe123 say also work in BMW ESP system. I have a friend with .:R20. Will try on his car next week
