Its file of MVVL damp.
You write:
"Hi.
Please help me.
A168 key problem.
I write neu transponder, do not start.
How to close the transponder?
ThanxW168 HC05 (1D69J) A Class.rar"
Post screen of your transporder (writen) or write more what You do. If You make its of keymaker - not need any add (close, config, etc)
I not understand: You make chip of keymaker or directly write damp?
andrei1302 (10th July, 2021)
Hello.
I write a new key directly from the dump with the abrites clone. Unfortunately, the car does not start.
I can see that zedbul offers a lot of settings, but it can't generate a the dump key directly.
I’ve read in several places that it needs to be closed somehow after writing and then it will work.
For me this is the first a168 mercedes and I don't understand.
moto.
Do You create the damp for chip (PCF7935) and then write its damp to chip or You load damp of IMMO to keymaker an this program writes chip?
Post any screen, I not undersand what You do
If You create damp for chip - post its damp
Hi adikk
please help
Mercedes benz a class W168
program by avdi can't start
TMpro said uknown size
bsr
hc05x16.rar
hi, I have a mercedes R170 with immobox 178201726 ID69J EEPROM damaged, I put a used car starts but remote controls do not work, can you help me?
Hey Adikk, I've got an issue on a R129. Tried to make a spare. Can you have a look at this file and make sure it's good?
I'm an idiot. no help needed.
PierreTheron (6th May, 2021)
Hi, friend Can you calculate keys for clk immobox 1688200426 its a 1D69J Mask. Thank's all for help
Hi Adikk
could You help with AKL situation on Mercedes A-class W168 MY2003
there is dump from Immobox Siemens 5WK4 with HC05X32
thx in advance
You have 3 used key (1-3). Write any damp to chip and config its as write in .txt And pls check your Immo box - if its have error "defective modul" - write mod fille to IMMO
andrei1302 (10th July, 2021), zyjekrc51 (10th July, 2021)
Hello adikk !
Please help me also with key files for W168 A-Klasse. Car is All keys Lost.
I read the 1d69J MCU with x-Prog 5.84, as Freescale/NXP HC05.
Please help also with instructions because I never succeded with these cars in the past.
Thanks a lot !
Uoy have 2 used key (1,2). Write any damp to PCF and config its as write in .txt
P.S. Andr try more help of other DK members ( You registration in 2019 a nd have 4 post)
Manta1600 (29th July, 2021), niboelectronic (21st August, 2021)
R170 immo 1D69J Help with calculating the key. Thank you
good, can someone help me with star error? W168 1688200426
Master Alientech, Magicmotorsport, Autotuner, file service,
Click on Thanks and Reputation if I helped you! Thank you
