You have 4 used key (1-4). Write any file to chip and config it as write in .txt
GMXcool (14th May, 2019)
Hello.
Mercedes A Class W168. I have only one key and want another.
Please generate one key. Many thanks in advance.
Your key #1, write damp to chip and config chip as write in .txt
hadrian (25th May, 2019), tenagliaspezzata (1st June, 2019)
Hi all
Mercedes A Class W168 1.4 engine code 166940
injection ecu A 166 141 31 25 VDO MSM 2.0
5wk4736 Immobox Motorola processor HC05X32 mask set 1D69J
the car give me start error
I have one transponder PCF7935 but I don't know if It is good
Tag key tool program It, but others virgin PCF7935 don't work (I think because they aren't rolling code)
Please Can You Help me
transponder image
You have 2 used key (1,2), write damp to chip and config its as in .txt
Hi adikk.
Could you please help me and generate one key.Merceds Aclass-W168, A170 CDI.
MCU D69J dump atach...
Thanks.
hello I need virgin dump for injection ecu A 166 141 31 25 VDO MSM 2.0 because car don't start
thanks in advance
Hi Adikk
Please generate key for merc A190 W168 immo 5WK4 736.This is lost key situation.Dump 1D69j read with x-prog.I have zedbul clone and Effi.
Thanks in advance!
Hi guys
Any help with this one please,only see key 4 in system.Is this rite? Must system have key no.1? Thanks
magicworx (20th July, 2019)
Thank you, will test and report.
Hi there
Still no go,Start Error on dash
