Please share I have a corrupted UPA clone, it came with no soft and I tried to install original drive which corrupted this chip.
Could you upload a dump for CLONE 24C128, please
Thank very much
Thank very much
if you use the search button, you will find the fix to your problem, you don't need to have the whole dump, just change the first bytes.
Thank, I read to change address 00 to 00.
Just wanted to make sure, here.
address $00 to $02 = C2B404
Hi, thanks for reply
Could you edit this file for me, so I know for next time. I'm not sure how to go about it
Thank you.
Is that what you ment?
yes, go ahead and test it; I don't know if it works, because i have original, but if you read the forums there are a few people here with the same problem you have and they said it worked for them.
I tried. It detects a new hardware, I'm able to install driver from ezusbw2k now. Looks ok but...
Then I run UPA 1.1. version and it recognizes new programmer for 5s and then USB power surge on Hub Port message comes up in windows and UPA soft promts :
EZUSB-0Error: 0
USB Module Disconnected
In device manager under cypress EZ-USB driver a message says:
Windows has stopped this device because it has reported problems. (Code 43)
try to change the usb cable, get a high speed one
Update!
After a reboot I was able to program!
The only concern is when I go in to TOOLS, HARDWARE TESTS. It gives that "Power surge error" I mention above and have to reset usb device manually.
Is this a normal behavior for a clone?
Maybe your UPA consumes too much power and the current from usb isn't enough. I have to use external power supply with my UPA because of this. When I tried it without external supply, my computer shut down usb completely and I had to restart my computer.
Maybe you should try another usb-port or get external supply.
Don't forget to thank when someone helps you!
Hi, guys,
Could someone send me clone's instructions, please? What jumper configuration should I have, mine aren't even labeled:
1.closest to power supply 3pin - 1/2, 2/1
2. on/off jumper, close to above
3. 4 pin
What should be correct config?
What amperage/voltage power supply?
Thanks, external power supply and info in the manual (read it first) SOLVED ALL THE POWER ISSUES.
Thanks for all your help and hope this will be of some use to others.
