Results 1 to 11 of 11
    Oct 2010
    fes, Morocco
    Default help on das xentry error fix
    hello DK's happy new year, I had a problem with my mux on das and Xentry. the mux work perfectly with the other cars very well with no cares except that it has a little problem with W204 when I plug my mux with it I receive an error on Xentry and das I search the forum and I realized that I have a blacklist I was able to fix the error on Xentry and now I can connect using the W204 with Xentry but I can't connect using das, because it is more convenient than Xentry and I wish you the best solution from DK Member I have das 07/2010 and thank you so much for all who think of me good night
    after 06-2009 you can't juse DAS for 204 and 212.
    you must juse Xentry.
    If you still want to, juse older version of DAS.
    Quote Originally Posted by e1nukke View Post
    I'm glad I did not know that and successfully connected with DAS to a W204. It should be the same for all using 07/2010. The 212 is a different thing though.
    Quote Originally Posted by khalilo814 View Post
    Which installation guide did you use, if any? Do you mean you cannot connect with a 204 via DAS or is it the same with all "genuine DAS cars"?
    Oct 2010
    fes, Morocco
    i had used zolookas guide first time when i was traying to connect to a w204 in my work shop i can't coonect with das and xentry and i can connect to auther car perfectly but when i want to coonect to w204 in xentry i have to error message Fault (1.17)-7.870 ;(2.27)-7.870 and yesterday i have solved the problem with xentry but das stell get an error i think it's a blacklist blocker can any one help mee please best regard
    Oct 2010
    fes, Morocco
    hi DK's can any one give me the best solution
    DK Veteran wsc's Avatar
    GR
    search for xentry..fault..two mr impactops has post the solution for blacklist Mux s
    Smart car engineer ,
    Oct 2010
    fes, Morocco
    can any one get more information top fix this error
    xentry error when connecting to a car anyone help me please thanks in advance
    Is it possible to get a Blacklist error only on model 204 I Thought blacklist means no communication at all?
