Results 1 to 7 of 7
    DK Veteran JIMMYQ's Avatar
    Mar 2008
    Default how do you program peugeot 306 keys??
    hi guys tried programming an old peugeot 306 had no keys cut a key have pin code etc. Anyhow tried programming with t300,mvp and sbb with t300 and mvp all i get is keys erased then how many keys i want to program i select one than after this all i get is switch ignition on/off then insert key to be programmed etc and it just keeps repeating this over and over again!!
    with the sbb it takes me the procedure then at the end it says no key preloaded??
    do i need 2 keys inorder to program if not whats the procedure as ive tried 2 306's now keep getting same thing!
    pin codes are correct so is the transponder im using
    Dec 2010
    What year is this Peugeot?
    Mar 2008
    tried doing a 1997 and a 2000 model
    the vehicle is accepting the programming sequence , so it can only be incorrect logic on your keys or a faulty ariel around the ignition , if its just lost keys and the vehicle was a runner before . it is pointing towards the keys
    Mar 2008
    thanks whats the correct transoponder to be used for these vehicles?
    Mar 2008
    coils are fine on both keys i was using Philips ID33 peugeot?
    EU
    try this logic it should work
    30 07 7E 00 FF 8F E3 C0 0F E0 F8 81 FF 00 70 1C
    regards
