Page 3 of 6 FirstFirst 123456 LastLast
Results 31 to 45 of 82
  1. #31
    V.I.P. Member barrowmanandrew's Avatar
    scotland
    try this
    user: root
    password: ukcvs.org
  2. #32
    Aug 2011
    Quote Originally Posted by barrowmanandrew View Post
    try this
    user: root
    password: ukcvs.org
    No luck
    Thank you for your help anyway kind sir
    Only managed FTA so far & must have tried//read forums for 100+hrs already. Was hoping to catch some of the cricket this week ;-)
    If no luck by end of play today, will try Jade3 again. Just was having problems with 28.4 instead of 28.2 on that image.
    Thanks again & have a tip top day
  3. #33
    May 2008
    if you are using capital letters for Root and Commando then you will not gain access to v14. there are NO capital letters in user or password for v14. try installing v14.3 and using the NEW passwords in post #32.
    Commando14.3 HERE
  4. #34
    Aug 2011
    Default Dreamup
    Are you using Dreamup
    Quote Originally Posted by gerry69b View Post
    sorry to say but i could not get neither v12 nor v14 to work on a dm500s
    it flashes on to dm box ok but on reboot it says it cant find any settings and is using neutrino defaults
    .. i tried to set to dhcp and activate network on boot .. when i reboot all saved settings are lost ..
    i am also told to scan for services .. only default satellite (astra e) is available.. i use a sky minidish ..
    no amount of fumbling with the service settings will get me to pick up a tv station ..
    it just looks like any changes i make are being ignored..
    the same thing happens on both version 12 & 14 so i am guessing i missed something some important in the pre-requirements
  5. #35
    Sep 2011
    Thank you for your work on this image, will try this on my dm500, currently using openplex but look for something more stylish, with more and nicer skins..
  6. #36
    Sep 2011
    hello can this image run mgcamb.? thanks
    ive put files in emu and the other files in kys and start mgcamb
    i like this image better tham emigma
  7. #37
    Feb 2011
    Hello Love the Commando 14 Image but am having trouble with cs-line in the image .. cannot get it to work .. do not quite grask how to chnmod .. Has anyone got a working image .. who could let me have it .. without cs-line but with instructions on how to add cs-line and chmod .. Please
  8. #38
    Feb 2011
    mmmmm so no one has commando 14 running then.
  9. #39
    Apr 2008
    ftp the CCcam binary into /var/bin/emu no need for chmod,
    just start the cam via the menu
  10. #40
    Dec 2011
    Awesome, will have a look at this thanks.
  11. #41
    Jan 2009
    Default Help Please
    Quote Originally Posted by Renwich View Post
    Could some please tell me where to get the CCam files for adding to the box and if it is possible to run MGCAMD instead of CCam
    Many Thanks NO10Ranger
  12. #42
    V.I.P. Member SatSearching's Avatar
    Apr 2008
    /tuxbox/enigma/src
    Google? (cccam.ppc)
    Thats 3 "C"s
    Are you saying Mgcam won't work?
    Quote Originally Posted by NO10RANGER View Post
  13. #43
    Old Git PaphosAL's Avatar
    Mar 2008
    Commando versions prior to 14.3 did not contain libcrypto.so.0.9.7 which mgcamd requires. So if you're running an older version, you can pop that file into /var/lib
    But you'd be far better off reflashing with the latest 14.4 release, then adding the latest channel picons package.
    Cheers- AL
  14. #44
    can someone please help i loaded 14.4 release but on the screen i get a message saying error no channels found
    i tryed scaning but still get the message,
    all cables are connected fine
  15. #45
    May 2008
    Quote Originally Posted by monsur View Post
    did you use DreamUP image flashing software to flash the commando image to your box?
    if not, then your image flashing software may not have overwritten the /var partition on the box with the one from the commando image.
    transfer commando image via ftp into the /tmp folder on your box and reflash via commando menu to make sure the image is re-flashed correctly.
    main menu > service > image upgrade/backup > flash a new image.
