Results 1 to 14 of 14
    peko's Avatar
    Default possible DAS without XENTRY ?
    hi friends
    is possible install DAS without XENTRY and work in develloper mode in w204 and w212 and W207 .... ???
    because i prefer use DAS as XENTRY , i don't think is same menu with same options
    thank you
    workshop
    you can buy hdd from china,w204 and 212 work on DAS
    How do you get 212 to work on DAS ?
    peko's Avatar
    so no other way fine to install DAS + XENTRY
    Benztown - Germany
    Quote Originally Posted by peko View Post
    I installed DAS 11.2010 without installing Xentry and it ran fine, if only my multiplexer wasn't broken.
    L
    peko's Avatar
    Quote Originally Posted by lingnoi View Post
    L
    ok very good job
    you can explain how made it and work on new E w212
    Benztown - Germany
    I used Zolookas guide and entered only a DAS key in Starkey (no Xentry key) and proceeded with install.
    After install finished I proceeded to connect system to my W204 and tried to connect. I say tried because after going through some connection steps it eventually stopped and gave an error code. I ran Caesar and found out that the multiplexer is defective (hardware error).
    I believe that my DAS install is fine considering I was able to get to connection stage.
    L
    peko's Avatar
    maybe is because your MUX is black-listed , you install fix about this error ?
    or maybe because DAS need password to work on w204, you install patch to remove this password ?
    204 can be diagnose by DAS but not 212, waiting for some good guy the share the method.
    peko's Avatar
    i read also guy write use das version 2010 on w204 and w212
    but i don't know method
    Quote Originally Posted by euror View Post
    I guess you mean everyone should be able to use DAS for the 204 with the few latest 2010 DAS releases? At least I did not need a password for 204.
    The 212 should be possible but needs some special knowledge (that I don't have).
    peko's Avatar
    yes friend, about 204 exist remove password ( I'm looking for it ) but don't have it and about 212 maybe is same technic
    if anybody want share info ...
  13. #13
    Benztown - Germany
    I have the w204 password fix. Send me a pm with your email details.
    L
  14. #14
    Aug 2008
    does anybody have that das patch ? that das works without xentry also?
