Results 1 to 7 of 7
Thread: Krypt > dbox2 ?
    Member Stu308's Avatar
    Feb 2009
    Default Krypt > dbox2 ?
    Hi, reading about on here , it seems that the kryptview boxes are still working on nag3. Is this correct?
    If so why on these boxes and not dbox2?
    Just want to clear it up in my head as I thought nag3 was uncrackable.
    Thanks.
    Nov 2008
    N*L EIRE
    Post
    Quote Originally Posted by Stu308 View Post
    Thanks.
    KV clear channs by accessing server via LAN-cable connected to
    internet. Dbox 2 has this capability if you can find cable-server
    for cable
    Mar 2009
    Behind closed doors !!
    you need more than a server, there is a lot more to it than that, if that was the case anyone could set a server up.
    Nov 2008
    N*L EIRE
    Post
    Quote Originally Posted by brainwave View Post
    Never said it was easy
    Quote Originally Posted by EAMO 2 View Post
    for cable
    So how do we get the Dbox working with working channels through a cable-server?? do you have all the information and a guide to do this
    V.I.P. Member jumpinjo's Avatar
    Apr 2008
    Quote Originally Posted by LDG View Post
    if it was available everybody would be doing it
    Nov 2008
    N*L EIRE
    Post
    I don't have info or guide. You will have to do research yourself.
    All I can tell you is that cable servers are working with DM500c.
    There was a few people having a go at D-box setup. I don't know how they got on. There is a Commando 12 & 14 image working on DM500s boxes with Cccam
    I would start with Commando 12 cable image on D-box & install
    Cccam 2.13 in var/bin/emu. Better still if Cccam 2.13 is listed in
    Commando online add-ons install it from there automatically.You
    will need to enter BOXKEY in Cccam/cfg. You may also need RSA
    key. I haven't even looked at my D-box for ages so I wouldn't be
    up to speed.
    Have a go at it if you have time, cable D-box is not much use as
    it is, so you have nothing to lose. Paul(plasterer) is very good on
    D-box & Desp Dan would be able to help you too
